just can't start my prusa
Posted by riptou
Re: just can't start my prusa
June 10, 2012 04:26AM
riptou Wrote:
> OK the extruder motor is working now. It's not
> turning, but it gets power as I can't turn it when
> it's on. I click on extrude 5mm or reverse, but it
> doesn't move.
> Frantz
For this I commented out the extrution safety feature in marlin configuration.h:
//#define PREVENT_DANGEROUS_EXTRUDE
Just to be clear: this must only be tested without the hotend attached to the extruder!
After calibration of your e steps enable the safety feature.
Oh and this error message:
: Extruder switched off. MAXTEMP triggered !
Error: Printer stopped deu to errors. Fix the error and use M999 to restart!.
For me was when i glued my thermistor wrong, shorting the wires inside the heaterblock.
Hi, i noticed you had this error.
I am having the same error when i try to set my machine driven to experimental Marlin
[00:41:03] Loading simulator.
[00:41:03] No bookend metadata specified for this machine
[00:41:03] Loading driver: replicatorg.drivers.reprap.RepRap5DDriver
How did you get past this?
Thanks a lot!!
