Is 12V and 1500mA enough to power a RepRap Prusa?
Posted by njken
January 27, 2013 06:46AM
I require a power supply to power my already assembled RepRap Prusa. The guide I got with the PCB says that I need 12v 5A max to power the printer. I came across a 12v1.5A power supply at home, and I was wondering if I could use that?
Re: Is 12V and 1500mA enough to power a RepRap Prusa?
January 27, 2013 07:46AM
I can't believe that is enough. Stepper motors draw potentially 1A each, then hotend requires another 2A and your heated bed needs like 10A at least. I don't know why there would be a MAX specification for current supply.
January 27, 2013 10:18AM
yea 5 amps would hardly be the minimum for a prusa without a heatbed.
Most of us aim for PSU's that can do up to 30 amps...
January 27, 2013 11:50AM
It would help if you said what PCB it was winking smiley
It sounds like it might be RAMPS which has a 12V 5A input, this is limited to 5A by a resettable fuse on the board. The 5A input is used to power motors and hot end but not the heatbed which has a seperate higher current 12V input.
A 1.5A PSU will not be enough though.
