reprapdiscount Wrote:
> I am not sure of the size and shape of their pcb,
> as far as i can see, they do not share it, maybe
> it's a non open HW project
> Regards,
> Reprapdiscount.com
Everything is Open if customers ask but since at monday a printable housing will be posted by you then we want test it and show how to fit PCB correctly to not doing a double job with design files and pictures and give all in one, but since our panel is 'plug and play' without knowledge about schematics etc. so publication of design files is not so urgent now.
Our panel is same size and also pinout compatible with ultipanel so I suggest your housing should be designed with care of default size without create new uncompatible size since .stl is impossible to edit and .stp just give possibility to edit few features then no place for user to tinkering and modifying it so I suggest sketchup or some OpenSource CAD standard this should be better for it.
Regards.
www.gadgets3d.com - parts for your 3D printer.
