Just found a bom if anyone else is looking.
1 x Print - Plastic Body V2 Extruder
1 x Print - Gear and drive set (small gear, medium gear, large gear, idler block, syringe pressure block
1 x NEMA17 motor
1 x T5 10teeth Metal drive Gear (you could print one of these)
4 x 624 Bearings
1 x 608 bearing
1 x 20mm M8 Smooth rod
1 x 55mm M4 Bolt
1 x 75mm M4 bar or bolt
1 x M4 Hex spacer (or M4 wingnut)
2 x M4 plain nuts
4 x M4 Nylock nuts
3 x M3 Nuts
2 x 20mm M4 bolts
5 x 10mm M3 bolts
4 x M3 washers
14 x M4 washers
3 x M3 nuts
1 or 2 x 45mm M3 bolts for Idler
1 or 2 x springs or Silicon pressure spacers for Idler
1 x small zip tie
1 x 5-6mm wide T5 belt ~about 40cm
1 x Plastic sheet
Standard 10ml Syringe - Luer Lock or Centre slip types
Various syringe needles 1.8mm - 0.1mm - For Lure Lock Syringe type.
