avrdude: AVR Part "atmega1284p" not found. error November 24, 2012 05:23AM |
Re: avrdude: AVR Part "atmega1284p" not found. error December 26, 2012 04:31PM |
Re: avrdude: AVR Part "atmega1284p" not found. error December 28, 2012 10:07AM |
Re: avrdude: AVR Part "atmega1284p" not found. error December 28, 2012 10:32AM |
#define word(...) makeWord(__VA_ARGS__)
// COMMENTED OUT THESE TWO DECLARATIONS AS THEY ARE DECLARED ELSEWHERE IN THIS FILE
//unsigned long pulseIn(uint8_t pin, uint8_t state, unsigned long timeout = 1000000L);
//void tone(uint8_t _pin, unsigned int frequency, unsigned long duration = 0);
void noTone(uint8_t _pin);
// WMath prototypes
long random(long);
long random(long, long);
void randomSeed(unsigned int);
long map(long, long, long, long, long);
/* LARS: YOU COMMENTED THIS OUT BECAUSE IT CONFLICTS WITH THE SAME DECLARATION IN THE PINS_ARDUINO.H FILE. // On the ATmega1280, the addresses of some of the port registers are // greater than 255, so we can't store them in uint8_t's. extern const uint16_t PROGMEM port_to_mode_PGM[]; extern const uint16_t PROGMEM port_to_input_PGM[]; extern const uint16_t PROGMEM port_to_output_PGM[]; extern const uint8_t PROGMEM digital_pin_to_port_PGM[]; // extern const uint8_t PROGMEM digital_pin_to_bit_PGM[]; extern const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[]; extern const uint8_t PROGMEM digital_pin_to_timer_PGM[]; */
Ruben
Re: avrdude: AVR Part "atmega1284p" not found. error January 08, 2013 06:51PM |
Re: avrdude: AVR Part "atmega1284p" not found. error January 09, 2013 05:42AM |
Re: avrdude: AVR Part "atmega1284p" not found. error February 01, 2013 03:31PM |
Re: avrdude: AVR Part "atmega1284p" not found. error February 11, 2013 06:53PM |
Re: avrdude: AVR Part "atmega1284p" not found. error February 12, 2013 10:26AM |
Re: avrdude: AVR Part "atmega1284p" not found. error February 12, 2013 11:42PM |
Re: avrdude: AVR Part "atmega1284p" not found. error February 17, 2013 04:20PM |
Re: avrdude: AVR Part "atmega1284p" not found. error February 17, 2013 08:04PM |
Re: avrdude: AVR Part "atmega1284p" not found. error February 26, 2013 06:21PM |
Re: avrdude: AVR Part "atmega1284p" not found. error March 01, 2013 06:31AM |
Re: avrdude: AVR Part "atmega1284p" not found. error March 11, 2013 03:12PM |
Re: avrdude: AVR Part "atmega1284p" not found. error May 08, 2013 07:15AM |
Re: avrdude: AVR Part "atmega1284p" not found. error June 12, 2013 01:35PM |
Re: avrdude: AVR Part "atmega1284p" not found. error August 03, 2013 12:05PM |
