Hello,
When a new layer is put on top of the lower layer, what makes it to stick?
1) Does the lower layer need to be still in melt state, or at least semi-melt (soft?) state?
2) Or, does it only need to be warm.. warm enough?
3) Or, it doesn't even matter that as long as the new layer is placed with a melted plastic, it will bond to the lower layer, like its own heat will melt the surface of the lower layer just enough to make a strong bond?
I think #3 is very unlikely... well, it will be cool if it was, since if it was true I can stop printing in the middle, and continue from where I left off a day after.Also, it will make printing complex shapes easier. We may even be able to increase the structural strength, by having different layer direction in one object...
How about #2? If that's the case... as long as I can warm up the already printed object enough (using a UV ray?), then I may be able to do the things I said in my wish list above, right?
If it's case #1... well, that's not only disappointing, but it also means the size of the printed object will not only constrained by the size of the platform and length of the rods, but also speed of the printing - when printing a large layer, the area which was printed first may have cooled off/hardened by the time the extruder finally made its way back to print a new layer on top of it after finishing the rest of the lower layer...
