When I wired up i my board I used the ramps diagram at( [reprap.org]). When I did that it shows the Z axis motors connected by a screw terminal that is attached to the back row. Would it be possible to move the z axis cables to the front set of pins instead of the back set of pins. Also instead of doing that could you put each motor into the set of pins ( back and front)?
Thanks
If you look at the traces, each set of pins is connected identically, so you can use either socket, or plug a motor to each socket rather than splitting the wires later.
