PLA Warping
Posted by keukpa
PLA Warping
June 23, 2012 08:27AM
Hi all,
I've just built my first Prusa (ABSPrusa) and I must say I am amazed! My first print was amazing and the 2nd and 3rd just as good. However, I've noticed that the corners of my prints are warping slightly.
I'm printing with PLA
I'm using a heatbed (@60C)
I'm printing directly on to glass.
I'm printing my PLA @200C
Could anyone offer any tips on preventing the warping? Should I print on to Kapton tape?
Many thanks,
Keukpa
I've attached the print that warped.
PLA Warping 1
PLA Warping 2
Re: PLA Warping
June 23, 2012 12:24PM
You can play with the bed temperature and first layer temperature, I've personally never had any luck with PLA directly on glass, all my large prints warped like yours.
I don't have the issue with PLA on Kapton, and PLA on blue painters tape sticks way too much, but I'll use it if I definitively can't have curling.
Re: PLA Warping
June 23, 2012 12:30PM
Thanks for the tips.
I've put some Kapton on the glass, so going to see how that prints.
I must say, I'm very impressed to have this working currently as well as it does!
Cheers,
Keukpa
Re: PLA Warping
June 23, 2012 02:27PM
Have a look at this thead
Re: PLA Warping
June 23, 2012 03:06PM
You should only need glass for PLA. Try dropping the temperature to 55C. It needs to be below the glass transition temperature.
Re: PLA Warping
June 23, 2012 04:08PM
Thanks nophead, I'll give this a go and see if it helps. Cheers,
Keukpa
Re: PLA Warping
Wow, thanks Glyn, excallent thread!
Keukpa
Re: PLA Warping
June 24, 2012 12:28AM
Make sure the glass is cleaned between prints, I do mine before each print starts, use something like rubbing alcohol I use methylated spirits and my PLA sticks amazingly well
__________________________________________________________________________
Experimenting in 3D in New Zealand
RAF
Re: PLA Warping
June 25, 2012 03:46AM
I never use any heated platform for PLA print, just scotch tape at platform and cooler this is enought. Optimal temperature to start with PLA is 220C later you can decrase it slowly and see results smiling smiley
Cheers,
Rafal
www.gadgets3d.com
Edited 1 time(s). Last edit at 06/25/2012 03:52AM by RAF.
open | download - IMG_4004.jpg (36.7 KB)
open | download - IMG_4011.jpg (74.5 KB)
open | download - IMG_4012.jpg (71.2 KB)
