x axis problem PRUSA I3
Posted by Govanator
May 20, 2014 11:31AM
Fellow reprappers,
I have a serious issue with my x axis,
when i try to move it makes a very weird "blocking" noise, like if the motor tries to move the axis and hold it stil at the same time.
I changed current with no succes.
Then i changed ports, and made the x axis work on the z axis, wich worked! so the x axis stepper motor is not broken.
thx
Edited 1 time(s). Last edit at 05/20/2014 11:59AM by Govanator.
Re: x axis problem PRUSA I3
May 20, 2014 01:53PM
Sounds like an issue I had when first starting...
[forums.reprap.org]
May 20, 2014 04:22PM
Have you tried the Y axis motor in the X axis connection? This would tell you whether there is a problem with the stepper driver.
[3DKarma.com] - suppliers of quality, affordable 3D printer kits and filament for the UK market.
May 20, 2014 04:29PM
is it moving in the right direction
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
May 22, 2014 08:35AM
thx guys,i found the issue, it was the stepper driver wich was defect
