I just smoked my Melzi electronics! May 28, 2014 02:35AM |
Re: I just smoked my Melzi electronics! May 28, 2014 11:38AM |
Re: I just smoked my Melzi electronics! May 28, 2014 01:12PM |
Re: I just smoked my Melzi electronics! May 28, 2014 03:42PM |
The MOSFET transistors used will literally let out magic blue smoke if used with a standard Mk2b PCB heated bed wired for 12V. With 12V input voltage, and the Mk2b bed wired for 24V, the bed does not get hot enough to be useful. And when wired for 24V and given 24V input voltage, it does work, but only if an external heatsink is added to the MOSFET. This is very dangerous, and at the very least, the specifications of voltage and current should be disclosed to the user so they can add appropriate external MOSFET or solid-state relay. Obviously, as mentioned before, there are no specs anywhere on what sort of current/power the heated bed circuit can handle. The Geeetech boards do not use the RFP30N06LE's like the original Melzi board spec'd out, so I am unsure of exactly how much current and power it is capable of. Please use caution when hooking up a heated bed to this board.
Re: I just smoked my Melzi electronics! May 29, 2014 01:36PM |
Re: I just smoked my Melzi electronics! May 29, 2014 03:13PM |
Re: I just smoked my Melzi electronics! June 04, 2014 09:52AM |
