Can i start RAMPS without heater bed connected? June 05, 2014 02:09PM |
Re: Can i start RAMPS without heater bed connected? June 05, 2014 02:22PM |
Re: Can i start RAMPS without heater bed connected? June 05, 2014 02:52PM |
#include "thermistortables.h" #define X_STEP_PIN 54 #define X_DIR_PIN 55 #define X_ENABLE_PIN 38 #define X_MIN_PIN 3 #define X_MAX_PIN 2 #define Y_STEP_PIN 60 #define Y_DIR_PIN 61 #define Y_ENABLE_PIN 56 #define Y_MIN_PIN 14 #define Y_MAX_PIN 15 #define Z_STEP_PIN 46 #define Z_DIR_PIN 48 #define Z_ENABLE_PIN 62 #define Z_MIN_PIN 18 #define Z_MAX_PIN 19 #define E_STEP_PIN 26 #define E_DIR_PIN 28 #define E_ENABLE_PIN 24 #define Q_STEP_PIN 36 #define Q_DIR_PIN 34 #define Q_ENABLE_PIN 30 #define SDPOWER -1 #define EXTRUDERS 3 #define TEMP_SENSOR_AD595_OFFSET 0.0 #define TEMP_SENSOR_AD595_GAIN 1.0 #define THERMISTORHEATER_0 1 #define THERMISTORHEATER_1 1 #define THERMISTORHEATER_2 1 #define HEATER_0_USES_THERMISTOR 1 #define HEATER_1_USES_THERMISTOR 1 #define HEATER_2_USES_THERMISTOR 1 static void *heater_ttbl_map[EXTRUDERS] = { (void *)heater_0_temptable #if EXTRUDERS > 1 , (void *)heater_1_temptable #endif #if EXTRUDERS > 2 , (void *)heater_2_temptable #endif #if EXTRUDERS > 3 #error Unsupported number of extruders #endif }; static int heater_ttbllen_map[EXTRUDERS] = { heater_0_temptable_len #if EXTRUDERS > 1 , heater_1_temptable_len #endif #if EXTRUDERS > 2 , heater_2_temptable_len #endif #if EXTRUDERS > 3 #error Unsupported number of extruders #endif }; #define PGM_RD_W(x) (short)pgm_read_word(&x) #define SDSS 53 #define LED_PIN 13 #define FAN_PIN 9 #define PS_ON_PIN 12 #define KILL_PIN -1 #define HEATER_0_PIN 10 #define HEATER_1_PIN 8 #define TEMP_0_PIN 15 // ANALOG NUMBERING #define TEMP_1_PIN 14 // ANALOG NUMBERING #define TEMP_2_PIN 13 // ANALOG NUMBERING void setup() { pinMode(TEMP_0_PIN , INPUT); pinMode(TEMP_1_PIN , INPUT); pinMode(TEMP_2_PIN , INPUT); pinMode(FAN_PIN , OUTPUT); pinMode(HEATER_0_PIN , OUTPUT); pinMode(HEATER_1_PIN , OUTPUT); pinMode(LED_PIN , OUTPUT); pinMode(X_STEP_PIN , OUTPUT); pinMode(X_DIR_PIN , OUTPUT); pinMode(X_ENABLE_PIN , OUTPUT); pinMode(Y_STEP_PIN , OUTPUT); pinMode(Y_DIR_PIN , OUTPUT); pinMode(Y_ENABLE_PIN , OUTPUT); pinMode(Z_STEP_PIN , OUTPUT); pinMode(Z_DIR_PIN , OUTPUT); pinMode(Z_ENABLE_PIN , OUTPUT); pinMode(E_STEP_PIN , OUTPUT); pinMode(E_DIR_PIN , OUTPUT); pinMode(E_ENABLE_PIN , OUTPUT); pinMode(Q_STEP_PIN , OUTPUT); pinMode(Q_DIR_PIN , OUTPUT); pinMode(Q_ENABLE_PIN , OUTPUT); digitalWrite(X_ENABLE_PIN , LOW); digitalWrite(Y_ENABLE_PIN , LOW); digitalWrite(Z_ENABLE_PIN , LOW); digitalWrite(E_ENABLE_PIN , LOW); digitalWrite(Q_ENABLE_PIN , LOW); Serial.begin(115200); } float analog2temp(int raw, uint8_t e) { #ifdef HEATER_0_USES_MAX6675 if (e == 0) { return 0.25 * raw; } #endif if(heater_ttbl_map[e] != 0) { float celsius = 0; byte i; short (*tt)[][2] = (short (*)[][2])(heater_ttbl_map[e]); raw = (1023 * OVERSAMPLENR) - raw; for (i=1; i raw) && ((float)(PGM_RD_W((*tt)[0]) - PGM_RD_W((*tt)[i-1][0])) >0)) { celsius = PGM_RD_W((*tt)[i-1][1]) + (raw - PGM_RD_W((*tt)[i-1][0])) * (float)(PGM_RD_W((*tt)[1]) - PGM_RD_W((*tt)[i-1][1])) / (float)(PGM_RD_W((*tt)[0]) - PGM_RD_W((*tt)[i-1][0])); break; } } // Overflow: Set to last value in the table if (i == heater_ttbllen_map[e]) celsius = PGM_RD_W((*tt)[i-1][1]); return celsius; } return ((raw * ((5.0 * 100.0) / 1024.0) / OVERSAMPLENR) * TEMP_SENSOR_AD595_GAIN) + TEMP_SENSOR_AD595_OFFSET; } unsigned long prevMillis; void loop () { if (millis() %1000 <500) digitalWrite(LED_PIN, HIGH); else digitalWrite(LED_PIN, LOW); if (millis() %1000 <300) { digitalWrite(HEATER_0_PIN, HIGH); digitalWrite(HEATER_1_PIN, LOW); digitalWrite(FAN_PIN, LOW); } else if (millis() %1000 <600) { digitalWrite(HEATER_0_PIN, LOW); digitalWrite(HEATER_1_PIN, HIGH); digitalWrite(FAN_PIN, LOW); } else { digitalWrite(HEATER_0_PIN, LOW); digitalWrite(HEATER_1_PIN, LOW); digitalWrite(FAN_PIN, HIGH); } if (millis() %2000 <1000) { digitalWrite(X_DIR_PIN , HIGH); digitalWrite(Y_DIR_PIN , HIGH); digitalWrite(Z_DIR_PIN , HIGH); digitalWrite(E_DIR_PIN , HIGH); digitalWrite(Q_DIR_PIN , HIGH); } else { digitalWrite(X_DIR_PIN , LOW); digitalWrite(Y_DIR_PIN , LOW); digitalWrite(Z_DIR_PIN , LOW); digitalWrite(E_DIR_PIN , LOW); digitalWrite(Q_DIR_PIN , LOW); } digitalWrite(X_STEP_PIN , HIGH); digitalWrite(Y_STEP_PIN , HIGH); digitalWrite(Z_STEP_PIN , HIGH); digitalWrite(E_STEP_PIN , HIGH); digitalWrite(Q_STEP_PIN , HIGH); delay(1); digitalWrite(X_STEP_PIN , LOW); digitalWrite(Y_STEP_PIN , LOW); digitalWrite(Z_STEP_PIN , LOW); digitalWrite(E_STEP_PIN , LOW); digitalWrite(Q_STEP_PIN , LOW); if (millis() -prevMillis >500){ prevMillis=millis(); int t = analogRead( TEMP_0_PIN); Serial.print("T0 "); Serial.print(t); Serial.print("/"); Serial.print(analog2temp(1024 - t,0),0); Serial.print(" T1 "); t = analogRead( TEMP_1_PIN); Serial.print(t); Serial.print("/"); Serial.print(analog2temp(1024 - t,1),0); Serial.print(" T2 "); t = analogRead( TEMP_2_PIN); Serial.print(t); Serial.print("/"); Serial.println(analog2temp(1024 - t,2),0); } }
Re: Can i start RAMPS without heater bed connected? June 05, 2014 04:31PM |
