Strange extruder feed problem Prusa i3 June 29, 2014 09:16PM |
Re: Strange extruder feed problem Prusa i3 June 30, 2014 12:31PM |
Re: Strange extruder feed problem Prusa i3 June 30, 2014 01:44PM |
Thanks Chris. Motor should be ok. I see the motor and feed wheel turning as they should ... just not filament going forward.Quote
chris33
Is the motor got enough torque i had similar issues i tuned up the amps on my motor but also check your hotend it may need a good clean
Re: Strange extruder feed problem Prusa i3 June 30, 2014 02:12PM |
Re: Strange extruder feed problem Prusa i3 June 30, 2014 04:39PM |
Re: Strange extruder feed problem Prusa i3 July 01, 2014 09:52AM |
Re: Strange extruder feed problem Prusa i3 July 01, 2014 12:28PM |
Thanks for feedback CF. Can't detect any obvious diff in glass level over that area and all good level in the 4 corners. Will do some more testing now with different area size test objects. Maybe the problem is with the stl file for my big object ... ???Quote
cat.farmer
it may be that your glass is not 100% flat, or your bed is not completely level. this causes the first layer gap to close up and jams the hot end. Check the z height with the bed and hot end at temp at several different spots, every 10 mm or so. you may need to adjust your first layer up a bit.
Re: Strange extruder feed problem Prusa i3 July 01, 2014 01:08PM |
Re: Strange extruder feed problem Prusa i3 July 01, 2014 01:24PM |
Oki, I'll try that. But that will only take care of getting like the 4 corners to be balanced yes ?Quote
chris33
I would look at the level of the bed i use auto bed leveling system and i have seen 100% improvement in get the 1st layer down since i implemented it
Re: Strange extruder feed problem Prusa i3 July 01, 2014 01:29PM |
Re: Strange extruder feed problem Prusa i3 July 01, 2014 02:17PM |
Re: Strange extruder feed problem Prusa i3 July 01, 2014 02:21PM |
Re: Strange extruder feed problem Prusa i3 July 01, 2014 02:25PM |
Re: Strange extruder feed problem Prusa i3 July 01, 2014 02:57PM |
Re: Strange extruder feed problem Prusa i3 July 01, 2014 03:13PM |
Re: Strange extruder feed problem Prusa i3 July 01, 2014 03:28PM |
Agreed you want that first layer to stick but that is way too thin. What does it measure from the bed?Quote
chris33
floyed its ok to raise it but remember that you want it to stick its better getting 1st layer squished into the bed like it is on the right of the picture the other bit over extruding
Re: Strange extruder feed problem Prusa i3 July 02, 2014 04:51PM |
