MendelMax 1.5 Z motor mount supports
Posted by Anonymous User
Anonymous User
July 08, 2012 04:02PM
Planning a MendelMax 1.5 build, using 8mm instead of the usual 10mm rails
looking at the thingiverse for MM 1.5 files:
MM 1.5 STL files
theres files for these RP parts:
Z_lower_motor_mount_10mm
'Z_lower_motor_mount_10mm_support 'normal' quantity 2
Z_lower_motor_mount_10mm_support 'mirrored' qantity 2
I've found a replacement for the stl file for:
with:
Z_lower_motor_mount_8mm_2_copies.stl
at
8mm rail files
but the latter doenst refer at all to these files:
first , do I need to go find a Z_lower_motor_mount_8mm_support or will the 10mm support work with the 8mm motor mount?
second , since there are 2 z motors mounts, presumably you can print either 2 normal of 2 mirrored, you don’t need to print all 4 , is that right?
Note, in case its relevant I have to hand two Thrust Bearings from my original MM 1.0 planned build
Also, for the z axis threaded rods I will be using 6mm instead of the more usual 8mm.
Thanks in advance,
Mike
Edited 2 time(s). Last edit at 07/08/2012 04:31PM by 3D2B.
Re: MendelMax 1.5 Z motor mount supports
July 08, 2012 08:04PM
All you need in 8mm size is the motor mount and clasp. The supports just attach to the side of the mount, and do not contact the 10mm rod, so the 10mm version will work with the 8mm motor mount. You need 2 each of mirrored and normal supports. Take a look at the assembly image there on thingiverse to see how the z motor mount is set up.
