SainSmart 12864 display April 30, 2014 11:17AM |
Re: SainSmart 12864 display May 01, 2014 02:32AM |
Re: SainSmart 12864 display May 01, 2014 02:40AM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: SainSmart 12864 display May 01, 2014 04:16AM |
blbergeson
I used this setup with a Megatronics 2.0 board. You will need the u8glib added into arduino's libraries. I believe Ultra_LCD and DogLCD needed uncommented also.
Re: SainSmart 12864 display May 01, 2014 04:17AM |
Re: SainSmart 12864 display May 01, 2014 05:52AM |
Re: SainSmart 12864 display May 01, 2014 07:22AM |
Re: SainSmart 12864 display May 01, 2014 04:38PM |
Re: SainSmart 12864 display May 01, 2014 04:44PM |
Re: SainSmart 12864 display May 02, 2014 07:42AM |
Re: SainSmart 12864 display May 03, 2014 08:03AM |
Re: SainSmart 12864 display May 04, 2014 07:58AM |
Re: SainSmart 12864 display May 05, 2014 02:01AM |
Re: SainSmart 12864 display May 05, 2014 03:57AM |
Re: SainSmart 12864 display May 05, 2014 06:07AM |
Re: SainSmart 12864 display May 05, 2014 03:06PM |
Re: SainSmart 12864 display May 05, 2014 11:20PM |
//LCD and SD support
#define ULTRA_LCD //general LCD support, also 16x2
#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family)
#define SDSUPPORT // Enable SD Card Support in Hardware Console
//#define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you're getting volume init error)
//#define ENCODER_PULSES_PER_STEP 1 // Increase if you have a high resolution encoder
//#define ENCODER_STEPS_PER_MENU_ITEM 5 // Set according to ENCODER_PULSES_PER_STEP or your liking
//#define ULTIMAKERCONTROLLER //as available from the Ultimaker online store.
//#define ULTIPANEL //the UltiPanel as on Thingiverse
//#define LCD_FEEDBACK_FREQUENCY_HZ 1000 // this is the tone frequency the buzzer plays when on UI feedback. ie Screen Click
//#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100 // the duration the buzzer plays the UI feedback sound. ie Screen Click
// The MaKr3d Makr-Panel with graphic controller and SD support
// [reprap.org]
//#define MAKRPANEL
// The RepRapDiscount Smart Controller (white PC
// [reprap.org]
//#define REPRAP_DISCOUNT_SMART_CONTROLLER
// The GADGETS3D G3D LCD/SD Controller (blue PC
// [reprap.org]
//#define G3D_PANEL
// The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PC
// [reprap.org]
// ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com]
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
Re: SainSmart 12864 display May 05, 2014 11:24PM |
Re: SainSmart 12864 display May 05, 2014 11:26PM |
Re: SainSmart 12864 display May 06, 2014 03:22AM |
Re: SainSmart 12864 display May 06, 2014 03:24AM |
Re: SainSmart 12864 display May 06, 2014 06:44AM |
blbergeson
I didn't have to change anything in the pins.h file to get the LCD working. But that may be necessary to get the SD card working on the LCD. The microSD card worked on the motherboard just not on the LCD.
Re: SainSmart 12864 display May 06, 2014 09:46AM |
Re: SainSmart 12864 display March 16, 2015 05:33AM |
