new prusa, a bit bigger
Posted by jf pion
July 14, 2012 08:45AM
As I found the prusa on the small side, specially on z, I designed one, slightly bigger with part from the local hardware shop: aluminium square tube 20*20 mm, 4 threaded rod 10 mm, smooth rod 10 mm 3lm10UU bearing and abs printed parts
the picture of the project is joined
the frame parts are mostly printed
the frame is secure to the plastic parts with 3.9 parker screw
the x axis get a vertical topology to allow easy change of extruder and easy fan setting
the frame is wide enough to allow double extruder in the future
do you have some comment/suggestion ?
thank you
open | download - projet.JPG (107.2 KB)
Re: new prusa, a bit bigger
July 14, 2012 09:28AM
Makes sense. I wouldn't call it a Prusa though, seems like a new machine descended from Mendel.
I have tried suspending a Wades from a right angle printed bracket. I found it changed the Y position of the nozzle during the first few layers as the heated bed caused the bottom of the bracket to expand more than the top and hence curl it slightly. One of the reasons I stuck with a horizontal axis on Mendel90. I think you need an extruder with vertical mounting points.
July 14, 2012 10:24AM
yes you're right more a new mendel, I looked on big mendel but I can't find the extruded aluminum part, and I want to use very common stuff.
for the X carriage I want to add a small fan to cool the upper part of the hotend (get some pb with PLA and Budaschnozzle, so even if the jhead mk4 doesn't really need it ....) do you think it will cool the carriage enough ?
I want to make it strong I thought of 8 mm infill 60% ABS dou you think it will be enough ?
otherwise I can make a part to fix the upper side of the extruder to the vertical wall of the x carriage with the upper motor screw
and I planned to have the motor through the wall to get a better balanced carriage (see the pic)
thank you for the advice I haven't thought of the thermic curl effect
open | download - x carriage.JPG (139 KB)
July 15, 2012 04:58AM
Maybe. I don't really know without experimenting. I don't use fans because I find a draught causes ABS parts to warp and lift off the bed. People seem to state the opposite with PLA.
That would be plenty strong enough to hold the weight I think. Thermal stability is the issue. With the typical length of a nozzle the angle of the base only has to change a minute amount to cause a significant offset of the nozzle. Something like 0.05mm is going to be noticeable.
The effect I noticed was the nozzle moved one way during the first few layers as the bracket warmed up close to the hot bed. It then slowly moved back over subsequent layers as the carriage moved away from the bed and the bed also cooled after the first layer.
July 18, 2012 06:34PM
i'm thinking about 2 fans: one for the upper part of the hotend to cool the cold side of the hot end which could be always on also with the abs with a duct to avoid blowing on the part
an an another for the part when using pla specially small part with thin wall ( and yes it increase the reliability of the print work, it's easier to get the good result the first try)
for the wrapping effect I found the brim in skeinforge or slic3r not strong enough for the big parts. I use build in design pad quit big ones of 2 layer of 0.25 mm high ) perpendiculary cross and found it quite effective and easy to remove with cutter, a lot of easier than raft in fact
see the joined stl
and also some picture of the frame
open | download - structure.jpg (564.5 KB)
open | download - coin bas.jpg (332.8 KB)
open | download - support mot.jpg (370 KB)
open | download - support moteur z a.stl (130.9 KB)
July 22, 2012 11:23AM
I have been printing PLA exclusively for over 2 years now (with a heated bed the last year) and do not need any fan.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
July 22, 2012 12:40PM
> not need any fan.
it's depend what you print and with which PLA
I found very difficult without fan to print one width wall quite high or very small bits
with the fan it's ok on the first try, so why taking the hard way ?
you don't need fan ? great some other need it, so it's better to design the thing with the possibility in mind
July 22, 2012 02:28PM
> not need any fan.
With the PLA that I have, sharp overhangs start to curl up, even on larger prints, if I do not use a fan. The result is that the curling is eventually severe enough that the hot end either knocks the print off the bed, or the motors skip steps running into the curled part.
I think it does depend on the specific PLA that you have. I have been printing exclusively with PLA for four years now, and in the past have been able to print PLA without a fan.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
August 25, 2012 06:34AM
Can someone point me in the right direction on where to find the stl files for this build? Thank you
August 25, 2012 09:03AM
what software do you use to draw that?
> parker screw
> in the future
> thank you
August 25, 2012 12:58PM
the files are here:
[www.thingiverse.com]
new add the x carriage with transverse wade extruder in one piece , sliced in 2 parts for easy printing
the others parts will follow (it is nearly completed, need only the small part like x belt fixation ant tensioner, end course switch support)
and i have to make the bed ant its fixation
I'm doing that [www.thingiverse.com] for the electronic
