Ramps 1.4 - Repetier Firmware - Not Supplying Power To Heaters
Posted by masonmilby
April 18, 2015 02:45PM
Hello, I have been building my new Prusa i3 for awhile now. Everything is fine except my SECOND Ramps 1.4 board (The first one did the same thing so I bought another) absolutely refuses to send power to any of the heaters. I have been at it for weeks now and I cannot get anything to work. Last night I did end up getting it to work and when I reconnected to it--nothing. I have tried setting the heater pins to the standard 10, 9, and 8 digital pins in the Repetier online firmware configuration tool but that doesn't work either. As I said I have a Ramps 1.4 board running Repetier firmware. I have checked both fuses any they are not tripped. Could anyone help? I have attached the Rep. firmware in a zip file and here are some pictures of my board and the only things I have plugged in.
open | download - Repetier-Firmware-2015-04-18.zip (344.8 KB)
Re: Ramps 1.4 - Repetier Firmware - Not Supplying Power To Heaters
April 19, 2015 01:10AM
What is the reading of your thermistor?
Are they in working condition eg. Reading correctly the temp?
If they are then check the wiring!
Good luck!
