I currently working on my first delta, and have run into a bit of an issue with when using the autolevel / autocalibration tools in marlin.
I am using Rich Cattel's version of marlin with autocalibration (G30), Rumba electronics, a simple normally open Z probe wired to Z min on the rumba board, and repetier host V1.0.4
I am currently manually releasing the Z probe for simplicity..
When I send either a G30 or G29 command the effecter moves to the start coordinates fine, but then it starts moving in the wrong direction.
Rather than moving down towards the print bed it moves upwards, and even when I trigger the probe manually as it is moving upwards nothing happens.
Iv checked the probe is working correctly with the M119 command, it registers open when the probe is deployed but not touching the bed, and triggered when it is.
Please help!
The link below is a video of what is happening.
Iv also attached my config file.
www.dropbox.com]
Thanks
Andy
