Extrusion Rate Changing September 14, 2015 10:25AM |
Re: Extrusion Rate Changing September 14, 2015 10:56AM |
Re: Extrusion Rate Changing September 14, 2015 11:06AM |
Re: Extrusion Rate Changing September 14, 2015 11:54AM |
Re: Extrusion Rate Changing September 14, 2015 11:57AM |
Re: Extrusion Rate Changing September 14, 2015 12:20PM |
kelen87
Thanks for the response!
The fan cooling the hot end down did come to mind. But when I look at the extruder gear while printing it goes at a slow "normal speed" during perimeters. But during the infill process you can see the gear has drastically sped up. I wouldn't think you'd be able to see full revolutions of the gear within a couple seconds, even if my hot end is indeed hot enough. Just seems "Hokey" lol pun intended.
