Using one power supply for a printer and a computer November 26, 2015 01:25AM |
Re: Using one power supply for a printer and a computer November 26, 2015 04:47AM |
Re: Using one power supply for a printer and a computer November 26, 2015 10:21AM |
Re: Using one power supply for a printer and a computer November 27, 2015 03:32AM |
Is there a better way to distribute the wires?
Re: Using one power supply for a printer and a computer November 28, 2015 01:42PM |
o_lampe
Sounds good to me.
Some people also use a 5v wire to power the boards logic ( and servos etc. )
You could feed 5V to an empty endstop header or a servo header, but you have to disconnect "D1" on the Ramps before.
-Olaf
Re: Using one power supply for a printer and a computer November 28, 2015 02:13PM |
Re: Using one power supply for a printer and a computer November 29, 2015 10:30PM |
cozmicray
This is NOT a good idea!
Maybe use computer power supply to power coffee maker and toaster?
With power supplies being so inexpensive'
Separate power supply and the isolation better
Long high current wiring + high current connectors not optimal
Fritz the supply --- No computer, No printer
Re: Using one power supply for a printer and a computer December 01, 2015 01:01PM |
Re: Using one power supply for a printer and a computer December 01, 2015 10:20PM |
Giantkiller
Expensive fires are caused by cheap incendiaries.
