Do you have heat sinks on the driver chips? Did it ever work more or less correctly even once?
Check your limit switches. (end stop switches) and make sure they are plugged in correctly to the board. Some connectors can be plugged in the wrong way though I am not familiar with the Folger. I have an i3 also but it is a Sunhokey.
Could be a bad driver chip for the Y axis. Check the board around the driver for solder bridges, etc. and also around the motor lead connection.
GrowleyMonster
Honemeister, Razorsmith, EV guy. Go ahead, ask me something.
