Ramps 1.4, Repetier and Opto-end stops February 03, 2016 09:46PM |
// ################ Endstop configuration ##################### #define ENDSTOP_PULLUP_X_MIN false #define ENDSTOP_X_MIN_INVERTING true #define MIN_HARDWARE_ENDSTOP_X true #define ENDSTOP_PULLUP_Y_MIN false #define ENDSTOP_Y_MIN_INVERTING true #define MIN_HARDWARE_ENDSTOP_Y true #define ENDSTOP_PULLUP_Z_MIN false #define ENDSTOP_Z_MIN_INVERTING true #define MIN_HARDWARE_ENDSTOP_Z true #define ENDSTOP_PULLUP_X_MAX true #define ENDSTOP_X_MAX_INVERTING false #define MAX_HARDWARE_ENDSTOP_X false #define ENDSTOP_PULLUP_Y_MAX true #define ENDSTOP_Y_MAX_INVERTING false #define MAX_HARDWARE_ENDSTOP_Y false #define ENDSTOP_PULLUP_Z_MAX true #define ENDSTOP_Z_MAX_INVERTING false #define MAX_HARDWARE_ENDSTOP_Z false #define max_software_endstop_r true #define min_software_endstop_x false #define min_software_endstop_y false #define min_software_endstop_z false #define max_software_endstop_x true #define max_software_endstop_y true #define max_software_endstop_z true #define ENDSTOP_X_BACK_MOVE 5 #define ENDSTOP_Y_BACK_MOVE 5 #define ENDSTOP_Z_BACK_MOVE 2 #define ENDSTOP_X_RETEST_REDUCTION_FACTOR 3 #define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 3 #define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 3 #define ENDSTOP_X_BACK_ON_HOME 1 #define ENDSTOP_Y_BACK_ON_HOME 1 #define ENDSTOP_Z_BACK_ON_HOME 0 #define ALWAYS_CHECK_ENDSTOPS 1
Re: Ramps 1.4, Repetier and Opto-end stops February 04, 2016 08:30PM |
#define ENDSTOP_PULLUP_X_MIN false #define ENDSTOP_X_MIN_INVERTING false #define MIN_HARDWARE_ENDSTOP_X true
Re: Ramps 1.4, Repetier and Opto-end stops February 06, 2016 06:13PM |
JamesK
if that was the only problem you'd still be able to see the values change when querying with m119, and it sounds like you're not getting that?
Re: Ramps 1.4, Repetier and Opto-end stops February 06, 2016 06:44PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 08, 2016 10:49AM |
Re: Ramps 1.4, Repetier and Opto-end stops February 08, 2016 10:55AM |
Re: Ramps 1.4, Repetier and Opto-end stops February 08, 2016 02:31PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 08, 2016 02:45PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 08, 2016 03:32PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 08, 2016 04:53PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 08, 2016 05:52PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 08, 2016 07:00PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 08, 2016 07:36PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 08, 2016 11:30PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 09, 2016 07:38AM |
Re: Ramps 1.4, Repetier and Opto-end stops February 09, 2016 11:10AM |
Re: Ramps 1.4, Repetier and Opto-end stops February 09, 2016 11:13AM |
Re: Ramps 1.4, Repetier and Opto-end stops February 09, 2016 12:48PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 09, 2016 03:17PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 09, 2016 03:26PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 10, 2016 11:54PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 11, 2016 06:53AM |
Re: Ramps 1.4, Repetier and Opto-end stops February 11, 2016 09:02PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 11, 2016 09:37PM |
Re: Ramps 1.4, Repetier and Opto-end stops February 13, 2016 09:18PM |
JamesK
Can you post a photo of the endstop connections on the ramps?
Re: Ramps 1.4, Repetier and Opto-end stops February 16, 2016 08:21AM |
JamesK
