Why not going a little bit bigger with your standard kit? February 15, 2016 10:27AM |
Re: Why not going a little bit bigger with your standard kit? February 15, 2016 03:07PM |
Re: Why not going a little bit bigger with your standard kit? February 15, 2016 05:51PM |
Re: Why not going a little bit bigger with your standard kit? February 15, 2016 06:47PM |
Re: Why not going a little bit bigger with your standard kit? February 16, 2016 01:57AM |
Re: Why not going a little bit bigger with your standard kit? February 18, 2016 12:51PM |
Re: Why not going a little bit bigger with your standard kit? February 19, 2016 04:47AM |
hello_tom
Sorry for the late response.
After doing some research about where to get the parts, I have to say that I must step back to 1.5mx3.0mx2.0m because the biggest aluminium bed I could find was a 1.5mx3.0m.
@ Govahnator: yes probably I will go for a Nema 24. Do you whether I can use it with my RAMPS 1.4? Thank you for the hint with the arduino duo 32 - I use that one. I hope I can realize it for 3.000 Euro, but my upper limit is 5.000 Euro. After the first draft I m optimistic that it could work with 3.000 Euro.
@ the_digital_dentist: I not plan to spend a lot for the frame. Some pillars and a frame on the top is what I want to use. If it s enough I can tell you hopefully at the end of next week. You say that things are getting really heavy. Right now if I take all the parts together of the biggest portable collection it weights around 15kg. I plan to use a 5mm alu plat. I will see how I can solve the heating issue. Last but not least money is available as well as time is.
@ o_lampe: It s going to be the garage.
I will keep you updated. I go shopping next Monday.
Re: Why not going a little bit bigger with your standard kit? March 09, 2016 04:58PM |
Re: Why not going a little bit bigger with your standard kit? March 10, 2016 03:28AM |
