RAMPS with Full Graphic Smart Controller TEMP problem March 24, 2016 01:49PM |
Re: RAMPS with Full Graphic Smart Controller TEMP problem March 25, 2016 05:48AM |
Re: RAMPS with Full Graphic Smart Controller TEMP problem March 25, 2016 06:08AM |
both temps the same, but when I try to print same gcode from sd(without connected PC) it heat to 245(set 255). when set 245 it heat to 235 . magicQuote
o_lampe
Pronterface only shows the temp coming from the Ramps/Arduino. It doesn't actively regulate anything, so both temps ( pronterface screen and LCD ) should be the same.
Re: RAMPS with Full Graphic Smart Controller TEMP problem March 27, 2016 05:54AM |
Re: RAMPS with Full Graphic Smart Controller TEMP problem April 19, 2016 06:45AM |
