Nut Trap vs Brass inserts
Posted by GRAYWOLF
July 02, 2016 07:30AM
Sorry if this has been brought up before.
I'm having issues with nut traps not printing clean leaving me with round holes.
To use the part and not throw it away, I have used heat pressed brass inserts.
M3 Brass threaded press in inserts.
This got me thinking, is there a reason why nuts were used in the design instead of Brass inserts?
Edited 1 time(s). Last edit at 07/03/2016 02:22AM by GRAYWOLF.
Re: Nut Trap vs Brass inserts
July 02, 2016 02:15PM
What design?
Is the round hole problem hardware or software related?
What have you done to find the source of the error?
July 02, 2016 04:07PM
If you can get a nicely-dimensioned hex trap, you probably don't need heat or much pressure to insert a nut, so they're nominally easier to use. Being smaller, they're easier to integrate into compact or complex designs. They're also more readily available, not a separate line item to procure on the BOM when there are other places you'll be using hex nuts anyway, and around 10% the unit cost.
Edited 1 time(s). Last edit at 07/02/2016 04:08PM by IMBoring25.
July 03, 2016 02:25AM
etfrench
What design?
All Designs.
etfrench
I'm holding it down to the fact my X-Axis tensioner was broke.
etfrench
Patched together a failed print enough to print a new replacement.
