first build voltages question
Posted by dmac257
September 10, 2016 07:56PM
I have in hand a 12V power supply .. arduino mega 2560/ramps 1.4/ 5X A4988 2A stepper driver boards .. 4 NEMA17 steppers motors for my first build.
I was supprised to see that the rated voltage for the stepper motors was only 3.1v 1.7a and I would like to know if this is correct or did I get the wrong steppers. I don't want to hook up the electronics before I double check.
Thanks in advance,
dmac257
Re: first build voltages question
September 10, 2016 08:09PM
You don't need to worry about the voltage rating, just the amp and mh ratings.
September 10, 2016 08:14PM
The voltage rating on steppers is simply the Current * Resistance of the device, its a fairly useless number
Steppers are always driven at much higher voltages, 3-4 times or more is quite normal
Edited 1 time(s). Last edit at 09/10/2016 08:15PM by Dust.
