SSR Wiring with Heatbed and RAMPS January 14, 2016 03:57PM |
Re: SSR Wiring with Heatbed and RAMPS January 14, 2016 05:07PM |
Re: SSR Wiring with Heatbed and RAMPS January 15, 2016 09:52AM |
Re: SSR Wiring with Heatbed and RAMPS January 15, 2016 10:22AM |
Re: SSR Wiring with Heatbed and RAMPS January 17, 2016 10:05AM |
Re: SSR Wiring with Heatbed and RAMPS January 17, 2016 11:13AM |
mhackney
I've been using this Auberins SSR on 6 printers with no issues at all. I switched to it after I had an SSR literally catch on fire while I was printing. This one doesn't even get warm even after a long print session.
Re: SSR Wiring with Heatbed and RAMPS January 17, 2016 04:31PM |
Re: SSR Wiring with Heatbed and RAMPS January 17, 2016 06:12PM |
Re: SSR Wiring with Heatbed and RAMPS January 17, 2016 06:19PM |
tKc
Will order as soon as possible, thanks again.
I took a shot at what the wiring will be like from your support/other stuff online (check out attached pic), does this work? Will just do 8 gage just to be safe for 20A.
After researching more I believe that bang-bang is the way to go but still not sure how to switch this in Marlin at all
Re: SSR Wiring with Heatbed and RAMPS January 17, 2016 07:10PM |
dave3d
I switched to a 24v Mk 3 heat bed controlled via a SSR and connected to Ramps.
dc/dc SSR rated at 40 amps. Simple wiring 2 wires in and 2 wires out.
Huge advantage. Bed heats up to 110 deg C in less than 2 mins. No heat from Ramps any more.
Just bang bang (on/off) control. Switch to Repetier firmware for Arduino. It is easier to configure.
WZ9V
I would swap the bed and the SSR in the diagram. I put the SSR on the low side, not sure if it matters.
Re: SSR Wiring with Heatbed and RAMPS January 18, 2016 06:14PM |
tKc wrote:
dave3d
How? Thought that a standard RAMPS could only handle 12V.
Re: SSR Wiring with Heatbed and RAMPS January 23, 2016 04:53PM |
Re: SSR Wiring with Heatbed and RAMPS January 24, 2016 05:47PM |
Re: SSR Wiring with Heatbed and RAMPS September 20, 2016 05:39AM |
Re: SSR Wiring with Heatbed and RAMPS September 20, 2016 09:08AM |
Re: SSR Wiring with Heatbed and RAMPS September 20, 2016 09:26AM |
Re: SSR Wiring with Heatbed and RAMPS September 27, 2016 12:41PM |
