heated bed false thermal runaway issue November 03, 2017 06:56AM |
Re: heated bed false thermal runaway issue November 03, 2017 08:07AM |
Adrenalized
I'm starting to run out of ideas.
My printer started stopping mid print while running marlin 1.0 . So I thought i should upgrade to the marlin 1.1.5 firmware (my thinking was Simplify3d was having a problem with my old firmware plus Repetier host wouldn't work at all)
This did not fix my stopping mid print problem. however Repetier host did start working.... small victory's.
On a side note I did change both the ramps 1.4 board and the mega.thinking if it was a faulty mosfet on the ramps that would sort it
After looking on the forum for people with the same problems I found the Thermal Protection parameters section in the configuration_adv.h
If you get too many "Heating failed" errors, increase WATCH_BED_TEMP_PERIOD and/or decrease
* WATCH_BED_TEMP_INCREASE. (WATCH_BED_TEMP_INCREASE should not be below 2.)
#define WATCH_BED_TEMP_PERIOD 160 // Seconds THIS WAS 60
#define WATCH_BED_TEMP_INCREASE .2 // Degrees Celsius THIS WAS 2
are you sure that the bed define change is 2 and not 0.2 as it looks in yours
As you can see I've changed this quite a bit. unfortunately it does not make any difference to the problem.
Today I tested the heating again. the bed was set to 90 degrees. The bed hit 90 degrees. Then got to 92 then seemed to drop to 87.70 then the dreaded .READ: Error:Thermal Runaway, system stopped! Heater_ID: bed
READ: Error: Printer halted. kill() called!
So all I can think it could be with my very limited knowledge of firmwares and electronics is
I did think about turning the bed thermal protection off but I don't think that is fixing the problem just side tracking it plus id like to not burn my house down.
Faulty bed thermister
heated bed mk2b alu
power supply loosing power 12v 360watt
all of the items above are over 2 years old. Can/do they wear out?
Re: heated bed false thermal runaway issue November 03, 2017 08:53AM |
Re: heated bed false thermal runaway issue November 03, 2017 02:37PM |
Re: heated bed false thermal runaway issue November 03, 2017 05:37PM |
Re: heated bed false thermal runaway issue November 10, 2017 11:29AM |
