How do you seal your heat block? September 26, 2018 01:54PM |
Re: How do you seal your heat block? September 26, 2018 02:15PM |
Re: How do you seal your heat block? September 26, 2018 02:53PM |
Re: How do you seal your heat block? October 03, 2018 12:09PM |
Re: How do you seal your heat block? October 03, 2018 12:28PM |
Re: How do you seal your heat block? October 03, 2018 12:49PM |
Re: How do you seal your heat block? October 03, 2018 03:25PM |
Re: How do you seal your heat block? October 03, 2018 04:41PM |
Re: How do you seal your heat block? October 03, 2018 06:13PM |
Re: How do you seal your heat block? October 04, 2018 01:02AM |
Re: How do you seal your heat block? October 04, 2018 06:59AM |
Re: How do you seal your heat block? October 04, 2018 10:57AM |
https://e3d-online.dozuki.com/Guide/V6+Assembly/6?lang=en
Step 26 Hot-Tightening
- Hot-tightening is the last mechanical step before your V6 is ready to go! Hot-tightening is essential to sealing the nozzle and heatbreak together to ensure that molten plastic cannot leak out of the hotend in use.
- Using your printer's control software (or LCD screen), set the hotend temperature to 285°C. Allow the hotend to reach 285°C and wait one minute to allow all components to equalise in temperature.
- Gently tighten the nozzle whilst holding the heater block still with a spanner and using a smaller 7mm spanner to tighten the nozzle. This will tighten the nozzle against the Heatbreak and ensure that your hotend does not leak.
- You want to aim for 3Nm of torque on the hot nozzle—this is about as much pressure as you can apply with one finger on a small spanner.
Re: How do you seal your heat block? October 04, 2018 11:21AM |
Re: How do you seal your heat block? October 04, 2018 11:28AM |
Re: How do you seal your heat block? October 04, 2018 12:20PM |
Re: How do you seal your heat block? October 04, 2018 06:18PM |
Re: How do you seal your heat block? October 05, 2018 12:25AM |
the_digital_dentist
The teflon in most (some?) doesn't extend down to the heater block- it stays up in the heatsink, so it never sees the high temperature.
Re: How do you seal your heat block? October 05, 2018 12:29AM |
Re: How do you seal your heat block? October 05, 2018 10:34AM |
Re: How do you seal your heat block? October 05, 2018 02:05PM |
Re: How do you seal your heat block? October 07, 2018 03:11AM |
Re: How do you seal your heat block? October 07, 2018 07:36AM |
Re: How do you seal your heat block? October 08, 2018 12:42PM |
Re: How do you seal your heat block? October 08, 2018 06:18PM |
Re: How do you seal your heat block? October 09, 2018 10:57AM |
Re: How do you seal your heat block? October 31, 2018 05:36PM |
Re: How do you seal your heat block? October 31, 2018 07:43PM |
Re: How do you seal your heat block? October 31, 2018 09:39PM |
Re: How do you seal your heat block? October 31, 2018 10:10PM |
Re: How do you seal your heat block? November 01, 2018 12:29AM |
SupraGuy
Spoke too soon.
It's definitely leaking between the heat block and nozzle threads, and is gradually getting worse. The top pf the heat block is staying clean, thanks for small miracles, but I'm getting an occasional booger of melted plastic dripping onto my printed parts. I cleaned it all up really well, and watched for a while. After a few minutes at 240°C there is a small bubble of melted plastic that appears on the side of the nozzle towards the heater.
This was a new heat block, new throat and new nozzle. I only re-used the actual heater unit from before. the screw for the heater was tightened until the heater was secure to a little bit of a pull on the wires. It was then heated to printing temperature, and then the nozzle was torqued tight. I did not heat it beyond printing temperature this time. The nozzle appeared to be flush against the bottom of the heat block when it was done.
Screw this. I'm putting a crush washer in next time.
