HEAT BED STAYS ON
Posted by Paul2d3d
HEAT BED STAYS ON
September 13, 2012 07:33PM
Heat Bed stays ON
When I switch on the power to my RAMP 1.4 on my prusa type design machine, the heat bed led comes on and the heat bed starts to heat up. It then stays on at the required temp until I turn the system off.
I am using Arduino, Marlin, Proterface and Slic R3. My ramps 1.4 is linked to a LCD controller
What have I done wrong !! sad smiley
Re: HEAT BED STAYS ON
September 14, 2012 01:09AM
Are you saying it goes beyond your intended temperature, or does it reach the target and then cycle on and off? If the first, then that is a problem. If the second, then its not a problem - that's the way it works. The hot bend remains heating until you explicitly turn it off.
I don't know what slicer you are using, but I use skeinforge, and I have a bit of custom end g-code that, among other things, turns my bed and hot end off
September 14, 2012 05:57AM
Thanks for your email
As soon as i switch the main power on the heat bed starts to heat up and stays on all the time at about 80 degrees to i switch the power off
ie gets hot before i have done any work and before i open up pronterface etc
thanks
Paul
September 14, 2012 01:31PM
Sounds like the FET has failed to a short, OR your microcontoller has embedded code to fire up the heater upon powerup.
September 14, 2012 07:23PM
Thanks will check both
Paul
