Log says "temperature sensor defect" March 09, 2019 04:49PM |
Re: Log says "temperature sensor defect" March 12, 2019 10:34AM |
Re: Log says "temperature sensor defect" March 12, 2019 12:02PM |
Re: Log says "temperature sensor defect" March 13, 2019 07:53AM |
dxnvrmx
Thank you for your reply.
1. Extruder isn't heating up at all, to test I pressed a piece of plastic onto it and it didnt melt.
2. The thermistor doesn't report a real temperature, it says that the Extruder is above 400 degree celsius which can't be because the max. temperature the extruder can reach is about 220-300 degree celsius.
3. No, its not spinning.
4. It doesn't heat up so its not working as it should.
I already checked all cables and restarted the printer and the slicer several times. I ordered a new thermistor and I hope it'll work afterwards.
Much appreciated
Re: Log says "temperature sensor defect" March 13, 2019 10:46AM |
Re: Log says "temperature sensor defect" March 13, 2019 01:00PM |
Re: Log says "temperature sensor defect" March 13, 2019 09:32PM |
Admin Registered: 13 years ago Posts: 6,990 |
Re: Log says "temperature sensor defect" March 26, 2019 03:04PM |
