Possible printer definition problem in Cura? June 11, 2019 08:13PM |
Re: Possible printer definition problem in Cura? June 12, 2019 04:14AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Possible printer definition problem in Cura? June 12, 2019 11:08AM |
Bernie
Well. I built a custom printer. RepRap coreXY . I’m ready to print. Tried today. Fired up all printer systems and ran operation check. Loaded object file with my custom defined printer selected in CURA. Sliced it saved it to SD card. Plugged it into my MKS sbase, 1.3, 32 bit/ tft 3.2 screen. Went to print icon and confirmed, then found file on the SD card. Printer started to print the “test XYZ cube” from Thingiverse. In the front left corner in a small square like it was going to print correctly then shot from homing at front left corner to rear right corner which over shot glass bed and I shut down immediately. I centered cube in my bed representation on cura before slicing and saving to SD card. Any ideas?
printer hot end not extruding June 21, 2019 04:58PM |
