Heated bed options for a Prusa-inspired delta printer August 19, 2019 05:33PM |
Re: Heated bed options for a Prusa-inspired delta printer August 20, 2019 02:42AM |
Re: Heated bed options for a Prusa-inspired delta printer August 20, 2019 11:26AM |
Re: Heated bed options for a Prusa-inspired delta printer August 20, 2019 11:47AM |
Raxius
Hi all,
I'm designing a delta style printer that takes a lot of design inspiration from the Prusa i3 Mk3.
This is the first printer I've built from scratch, so I'm sure there will be several other posts I'll make about it.
One of the features I really want to include is the magnetic removable bed.
The print surface seems fairly simple, it looks like a 22 ga spring steel plate with .25 mm PEI sheets on both sides.
The heater is a lot harder to replicate. I'm not even sure what it's made of, so I guess that's my first question.
If anyone knows more about it's construction and where to find more information on Prusa's BOM that would be extremely helpful.
Right now I'm thinking of using a 250mm silicone rubber heating pad or a pcb heater stuck to an aluminum plate with magnets glued into machined slots on the bottom.
I've seen a few other posts on here discussing the plate thickness and it looks like 6mm is a decent thickness for an aluminum plate, but that thickness seems like it would take a while to heat up.
Also any help sourcing this stuff would be greatly appreciated.
I'm also trying to find some good linear rails, but I'm having a hard time finding some that are good quality, but wont break the bank.
Does anyone know what's a typical price for 500-600mm lengths and what width is usually used for deltas?
Re: Heated bed options for a Prusa-inspired delta printer August 20, 2019 12:20PM |
Re: Heated bed options for a Prusa-inspired delta printer August 20, 2019 12:25PM |
Re: Heated bed options for a Prusa-inspired delta printer August 20, 2019 12:34PM |
Re: Heated bed options for a Prusa-inspired delta printer August 20, 2019 03:50PM |
Re: Heated bed options for a Prusa-inspired delta printer October 29, 2019 10:48AM |
