[solved] can someone help me identify this pcb? August 01, 2020 03:31PM |
Re: can someone help me identify this pcb? August 01, 2020 04:19PM |
Admin Registered: 11 years ago Posts: 3,096 |
We like the combination of Arduino MEGA2560 plus RAMPS1.4 and A4982 in 3D printer,and we also find some short for them.Such as we have to plus a lot,the volume is more big etc.
Then we design a new PCBA which combine all major features of these open-source PCBAs:Arduino Mega 2560, RAMPS1.4,step stick 4988.
MKS Base V1.0 has the powerful processor ATMEGA2560 WITH 256K flash memory. It use FTDI FT232R device for USB and not ATMEGA16U2 as ARDUINO MEGA2560. In power input, we use L5970D replacing the LM1117-5.0, which make MKS Base V1.0 supporting 24V or 12V input. And XH series sockets let us easy inset the wire of step motor and end stop.
Re: can someone help me identify this pcb? August 01, 2020 04:27PM |
Re: can someone help me identify this pcb? August 01, 2020 06:01PM |
ketchupOnWaffles
thank you very much, that's really helpful ^^
i'm trying the easy solution here, because using the E1 is juste switching numbers in the firmware
thank you again, is there a way to mark this as solved ?
