MendelMax+, 305mm x 305mm build area--Build Blog
October 14, 2012 07:34PM
I just thought I'd point you guys towards my build blog. I've been interested in RepRap since 2007 but just recently started back into it again. My project is a MendelMax that is scaled to a print area of 305mm x 305mm on the x an y axis. I'm trying to document it well so that others can use it as a basis for creating a slightly larger mendel max.
Thanks to the support from this forum and the MendelMax Support google group.
You can find the blog here.
[mendelmaxplus.blogspot.com]
All of the parts for this build are detailed on the blog (includes purchase location, price, and the shipping costs I paid).
Hopefully this helps someone, and I'd really appreciate your ideas/feedback.
Thanks,
Clay
Re: MendelMax+, 305mm x 305mm build area--Build Blog
October 20, 2012 10:51AM
Well, I finally got enough parts in to start assembly. Now my biggest challenge is building the build platform. If you have any suggestions I'd like to hear them.
Thanks a bunch!
Clay
October 20, 2012 06:12PM
wow i see u explored possibility of carbon fibre parts ... u know how to DIY them?
this is 1 of the designs that inspired my ,machine [www.youtube.com]
Edited 1 time(s). Last edit at 10/22/2012 04:34AM by redreprap.
October 22, 2012 08:56PM
I have an oversized MendelMax, approximately 350 mm x 310 mm build area. The platform is a sheet of 1/8" (3 mm) thick aluminum with power resistors bolted to the underside and picture glass on top. I use 10 5-Ohm 25-Watt resistors in series, run off of 110 V AC current using a solid state relay. This gives about 300 Watts of power, allowing the bed to reach a max temperature of 140 C. I use countersunk flat head screws to bolt the power resistors, and use thermal grease for good thermal contact.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
