Help with designing a belt tensioner March 28, 2021 06:07AM |
Re: Help with designing a belt tensioner March 28, 2021 08:45PM |
Re: Help with designing a belt tensioner March 29, 2021 06:16PM |
Re: Help with designing a belt tensioner March 30, 2021 06:24AM |
Re: Help with designing a belt tensioner March 30, 2021 07:40AM |
Re: Help with designing a belt tensioner March 30, 2021 05:07PM |
MechaBits
cant understand why the belt is tensioned on the Z, would need to see more, doesnt look like enough material for the idler post, what about another part to secure top of idler?
Re: Help with designing a belt tensioner March 30, 2021 05:12PM |
the_digital_dentist
In your build the working side of the X belt loop is the side closest to the extruder. It has to be parallel to the X guide rails. The other side of the loop doesn't. Add an idler on the nonworking side that can push against the belt to increase its tension.
That whole assembly looks a bit too flexy for me...
Re: Help with designing a belt tensioner March 30, 2021 08:04PM |
Re: Help with designing a belt tensioner March 31, 2021 12:04PM |
MechaBits
I too thought it was a bit flimsy but didnt know how thick it is 10mm 15 or 20 but the slot in the Z nut trap makes it weaker at a point, not sure why you have that, is it for some Z wobble thing?
In one of my printers I am using 2 rails with no support (though one rail is acting just as stiffener), I think I could go with one rail, but in yours maybe you could use 2 but closer together, back to back or above below, you might get more room, you wont have to worry about another idler pressing on the belt or more complicated belt paths, though adjusting idler can push or pull and throws up alternative ideas.
Is this for a bed slinger, 4x Z rails ?
Re: Help with designing a belt tensioner March 31, 2021 04:41PM |
Re: Help with designing a belt tensioner April 04, 2021 07:33AM |
MechaBits
also the slots for the rails dont really need to be there, thicker material in that point, shifting things up a tad might help with moving & improving the idler. I'd redesign the whole of x & z, just 2 rails for Z an one for X with a piece of 2020 for support....then with the 2 free linear guides maybe alter the bed next.
Re: Help with designing a belt tensioner April 04, 2021 09:14AM |
Re: Help with designing a belt tensioner April 05, 2021 05:11PM |
Re: Help with designing a belt tensioner April 06, 2021 07:28AM |
Re: Help with designing a belt tensioner April 07, 2021 12:21PM |
Re: Help with designing a belt tensioner April 07, 2021 01:27PM |
Re: Help with designing a belt tensioner April 07, 2021 01:38PM |
Re: Help with designing a belt tensioner April 07, 2021 02:18PM |
MKSA
With all these linear rails and Al extrusions why not build for example a CoreXY based on a proven built ?
Only a couple to choose from, so the choice is easy.
Re: Help with designing a belt tensioner April 07, 2021 03:03PM |
Re: Help with designing a belt tensioner April 07, 2021 03:20PM |
Re: Help with designing a belt tensioner April 08, 2021 02:58AM |
drmaestro
Any suggestions on which CoreXY models to choose from?
Re: Help with designing a belt tensioner April 08, 2021 06:47AM |
Re: Help with designing a belt tensioner April 08, 2021 08:15AM |
Re: Help with designing a belt tensioner April 08, 2021 11:32AM |
MechaBits
where's your core XY MKSA?
[1.bp.blogspot.com]
In this pic you can just about see the belt tension point and single screw, i have a closed loop belt on here, though it doesnt need to be, it makes it easy to pull the loop tight.
Re: Help with designing a belt tensioner April 08, 2021 05:56PM |
MKSA
Just have a look at the "Prusa" of the OP. It has more rails and Al profiles than a CoreXY but arranged in a quasi erratic way all assembled with flimsy 3D printed parts. A good belt tensioner won't change much and the one "designed" is a joke (not yours).
The OP could make two decents Prusa or one CoreXY So ?
It happens DD gives all the details to build a good CoreXY.
Re: Help with designing a belt tensioner April 13, 2021 01:18PM |
Re: Help with designing a belt tensioner April 14, 2021 02:19PM |
Re: Help with designing a belt tensioner April 14, 2021 02:39PM |
Re: Help with designing a belt tensioner April 14, 2021 03:26PM |
Re: Help with designing a belt tensioner April 15, 2021 01:19PM |
