What sanguinololu version board is this? Next steps to get it working?
Posted by yompyamper
July 27, 2021 07:29AM
Many years back, I bought a pre-assembled sanguinololu board from geeetech and I'm trying to get it to work now (I wasn't competent enough at the time).
After some research, I have managed to determine there is a bootloader on it, and have a setup that can install the firmware (I can talk to it in G-code now, 644P - 16MHz, Arduino IDE) but I don't know if it's BOARD_SANGUINOLOLU_11 or BOARD_SANGUINOLOLU_12.
When I send something like G0 X0, G0 X1000 (or other axes), nothing happens to the stepper motors. How do I determine if the pololu stepper drivers are still in order? (yes, they are the right way around on the board).
If I want to use the board to drive a CNC, are there any modifications I need to make?
Re: What sanguinololu version board is this? Next steps to get it working?
July 27, 2021 08:21AM
Geeetech Azteeg 3d printer board RepRap 3D Printer Controller Compatible With Sanguinololu
[www.geeetech.com]
as for which Sanguinololu its compatible with...
Has a circuit diagram here [www.geeetech.com]
and if we compare it with the table on [reprap.org]
Its should be compatible with Sanguinololu v1.2 onward
July 27, 2021 10:45AM
Thank you! I'm uploading the correct firmware straight away!
