Creality 4.2.7 END STOPS PROBLEM confused smiley
Posted by Moudry
September 22, 2022 04:21AM
Hello guys, is there a way to define min_end_stops pins as max_end_stops pins in Marlin 2.0.9.5?
Because Im building delta 3D printer based on Ender 3 with 4.2.7 board. (and ender 3 display)
And all MIN_END_STOPS are triggering (Checked with Pronterface) but motors do not stop when homing even when i define only them in Marlin, Configuration.h
And since Delta configuration in Marlin require MAX_END_STOPS and 4.2.7 board have only MIN_END_STOPS pins, should i add all MAX_END_STOPS definitions to pins_Creality_V427.h (pins_Creality_V4.h bacause its define V427 files) and set it to same pins as MIN_END_STOP use?
Bacause the definition of them is missing (Propably because the board doesnt have these plugs) so i cant simply just change the pins numbers.
Edited 2 time(s). Last edit at 09/22/2022 08:36AM by Moudry.
VDX
Re: Creality 4.2.7
September 22, 2022 04:33AM
... you can swap the pins ... or invert the homing direction ...
Viktor
Re: Creality 4.2.7
September 22, 2022 08:33AM
The homing directions are correct.
But how should I swap pins when the board file for pins look like this:
// Limit Switches
#ifndef X_STOP_PIN
#define X_STOP_PIN PA5
#endif
#ifndef Y_STOP_PIN
#define Y_STOP_PIN PA6
#endif
#ifndef Z_STOP_PIN
#define Z_STOP_PIN PA7
#endif
#ifndef Z_MIN_PROBE_PIN
#define Z_MIN_PROBE_PIN PB1 // BLTouch IN
#endif
#ifndef X_STOP_PIN
#endif
#ifndef Y_STOP_PIN
#endif
#ifndef Z_STOP_PIN
#endif
#endif
Should i rename that X_STOP_PIN ? Or somentihing?
Edited 2 time(s). Last edit at 09/22/2022 08:35AM by Moudry.
Re: Creality 4.2.7 END STOPS PROBLEM confused smiley
September 22, 2022 09:06AM
?_STOP_PIN are automatically min or max depending on if your homing to min or max
ie set the following and your done.
#define X_HOME_DIR 1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
You dont need to change pins...
Edited 1 time(s). Last edit at 09/22/2022 09:07AM by Dust.
VDX
September 22, 2022 09:36AM
... I meant to swap them "physically", if he won't change the defines smoking smiley
Viktor
September 23, 2022 02:10AM
You were right, thank you so much!!!
