Extruder stops extruding after a while
Posted by dcecurtis
November 22, 2012 01:29AM
I start a print on my reprap and the first couple layers print perfectly print great , and eventually my extruder keeps trying to extrude and i cant unless i give the plastic a push.
Thanks,
Daniel
Re: Extruder stops extruding after a while
November 22, 2012 02:27AM
Do you have a fan on it. Sounds like the temp is moving into the cold and making the plastic harder to move. Another option is that the pressure against the stepper drive is not hard enough and it slips and lastly you might not be having enough current going to the extruder stepper to move the filament when it starts to get tough to move.
November 22, 2012 05:59AM
Could be several things. If the extruder continues to move, but fails to extrude its probably one of the following.
1) the pinch wheel has stripped the plastic. Try reducing the pinch pressure slightly.
2) Temperature has gone down. It may have switched off. There is an over temperature setting in the firmware that switches off the extruder. I have had reading spikes and in the end have disabled this feature.
November 22, 2012 09:28PM
Ok, ill give it a try, Thanks for your help
