What power supply to use
Posted by joestefano
December 10, 2012 05:39PM
I purchased a MK2A Heated Bed for my RapMan 3.2. What should I use for a power supply? I am going to mount it under a pane of 3mm glass.
Re: What power supply to use
December 10, 2012 11:08PM
I use these: [www.ebay.com]
But a PC ATX supply would work just as well, as long as it can put out at least 15A on the 12V rail.
December 11, 2012 05:07PM
Yep but you cant just use a PC supply just like that, you need to short some pins so it will start and sometimes you need to introduce a load so the voltage will be stable. If you have the money get a nice LED power supply from ebay. If you want it faster I have also seen them on Amazon but they cost a bit more.
A 12volt 30a supply should be able to supply both your printer and the heat bed.
