Confusion over Z axis
Posted by KevinBennett126
February 03, 2013 06:36AM
Hi, I'm building a Prusa and have a question regarding the Z axis sense.
The instructions (on the Wiki/Prusa_build_Manual) say :-
" place the endstops at the 0 coordinate for each axis ...... Z axis moves downwards until the extruder nozzle is just barely above the bed"
& for sensing the stepper motor :-
" Tell the Z axis to move forward (positive) by 10mm. If it moves UP, write "OK" under Z "
Yet when I run PRONTERFACE and click on 'Home' the Z axis moves up .... I expected it to move down to the limit switch?.
Kevin.
Re: Confusion over Z axis
February 03, 2013 06:53AM
which firmware are you using? I think in marlin you need to invert a 2 of the axis by default. check that
February 03, 2013 07:04AM
> check that
Thanks,
I'm not 100% sure which firmware I have (it came pre-loaded on the board) but it did come with a CD with Marlin on it, so I guess that's what's loaded.
February 03, 2013 06:03PM
It may be easier to just reverse the Z motors wiring rather than play about with firmware.
February 03, 2013 06:42PM
It's one of the many options in the config. It's almost impossible to avoid tinkering with the config if you want to setup a machine correctly. And a much better option than messing with wiring if you ask me.
February 04, 2013 04:48PM
Mystery solved ...... I didn't have the Z axis end stop switch (normally closed) connected, so the 'Home' routine thought the switch was actuated, so it was driving the Z axis up to try and release the (non-existent) switch.
Kevin
