Progress Update
Posted by Leav
Progress Update
November 04, 2008 05:24PM
Hi Reprappers,
Iv'e been around the forum alot ad until recently i've been all talk and no walk...
So here is a small update from me and a small question/observation.
I am very impressed with the rigidity of the frame. it is much sturdier than I thought it would be.
Just a note: the 3D printer I have access to is an Objet one, which has tendancies to make any hole a wee bit smaller... this caused the Y idler houses (is that the correct name?) to crack when I forced the plastic bearings in... (not a good idea...)
Not a big deal since the rods going into the corner bracket take the load and pull it back together.
Check out the other attachments, and feel free to ask me questions if you have any....
-Leav
Edited 1 time(s). Last edit at 11/04/2008 05:26PM by Leav.
open | download - 100_0865.jpg (169.3 KB)
open | download - 100_0866.jpg (159 KB)
open | download - 100_0874.jpg (189.1 KB)
open | download - 100_0876.jpg (176.4 KB)
Re: Progress Update
November 05, 2008 09:49AM
Awesome! It's good to see a man of action on the forums! smileys with beer
How long did it take for the Objet to print out a Darwin? And how strong are the parts? They look very accurate.
As for hole sizes, I had access to a machinist's drill set - drill bits sized every 0.001" or 0.002" - that made the assmebly work a lot easier when I put my Darwin together.
How
Re: Progress Update
November 05, 2008 10:46AM
What did Objet charge to print the Darwin parts?
Re: Progress Update
November 06, 2008 01:44PM
Oh, I nver saw an Objet machine, not ebn on a photo or video. Can you give any details? Speed, quality, pricing of machine and material, availability?
Re: Progress Update
November 06, 2008 04:16PM
Looks like this is their website: [www.objet.com]
Re: Progress Update
November 06, 2008 04:51PM
Hi smiling smiley
----->>>>>>>>Awesome! It's good to see a man of action on the forums!
Thanks smiling smiley it's fun finally getting stuff done!
----->>>>>>>>How long did it take for the Objet to print out a Darwin?
I really couldn't say since the printing of the parts was spread out over several weeks when the printer was free.
I could try and guesstimate about 36 hours total running time since the large trays were about 10 hours each and there were 2.5 of those plus some smaller trays of tidbits I forgot the first times.
----->>>>>>>>And how strong are the parts?
They are strong, but somewhat brittle. we actually printed a model for stress testing in one of those machines that look like torture devices and pull the model apart while measuring stress and strain. I'll let you know the results if you're interested. smiling smiley
----->>>>>>>>They look very accurate.
They are! I am amazed by the detail it can produce. the head works like an inkjet printer! it has 36 (I think) heads that simultaneously deposit plastic while making a linear pass. it's pretty awe inspiring to watch.
----->>>>>>>>What did Objet charge to print the Darwin parts?
Not sure since it's a faculty printer (I'm a student here at the Technion [en.wikipedia.org] ) and I am lucky enough to not have to worry about the cost! cool smiley
Again I can estimate: printing all the parts cost something on the order of thousands of dollars eye popping smiley
but when I'm done I'm going to give that printer a run for it's money!
A room full of Darwins!
----->>>>>>>>Oh, I nver saw an Objet machine, not ebn on a photo or video. Can you give any details? Speed, quality, pricing of machine and material, availability?
Here is a great video showing an Objet machine in action:
[www.youtube.com]
Truly inspiring for me! I would never have believed that possible!
-Leav
Also, I just finished calibrating my Z-Axis! smileys with beer
Edited 1 time(s). Last edit at 11/06/2008 04:54PM by Leav.
VDX
Re: Progress Update
November 06, 2008 05:55PM
... they print with UV-curable resins and the strong light you can see are two UV-lamp-arrays beside the head.
This prototype of a micro-gripper is made by an Eden500 Objet-printer:
With a reprap/repstrap it's possible to dispense fluid PMMA (i have "ACRIFIX 192" from Degussa) with a syringe and cure the actual sheet wit an UV-lamp.
I'm testing with this type of 'room-temp' fabbing too, but for fast UV-curing i need powerfull (and expensive) UV-sources or the curing time per slice would exceed 15 minutes until it's hard enough for supporting the upper slices an the fabbing would last a very long time.
But the Acrifix-objects are fully cured like normal PMMA (plexiglass) and i didn't notice any warping with my first tests ...
Viktor
Re: Progress Update
November 08, 2008 07:10PM
2D printing for the win!!!
Also, a RepTube video:
[www.youtube.com]
I wrote some basic code for the arduino to do this just so I could sleep better tonight smiling smiley
Onwards! to the extruder!!!!!
-Leav
Re: Progress Update
November 08, 2008 07:40PM
Sweet!
Re: Progress Update
November 18, 2008 09:35AM
After some requests (ok just one smiling smiley ) I'm attaching some simple test codes here for straight uploading to the arduino.
These are based off of the codes in the wiki pages for the electronics.
Remember to tweak all the parameters for your system (e.g. the opto switch types and direction of the stepper motors) - I suggest just running it with a finger on the kill switch, that's how I tested out the direction and the opto switches.
hOMING - brings back all the axes one by one to the home position using only the opto switches as feedback (no sanity checks)
pRINToPTO - doesn't move any motors, only prints the status of the opto switches to the arduino IDE terminal.
rECTANGULARsPIRAL - prints the above rectangular spiral from the current position (no homing). width height and margins are easily modifiable.
enjoy.
-Leav
Edited 1 time(s). Last edit at 11/18/2008 09:36AM by Leav.
open | download - test_code.zip (186.6 KB)
Re: Progress Update
November 18, 2008 10:28AM
Hi Leav
Thanks! Just what I need to start checking my new repstrap, of which I only have the X & Y axis working at the moment.
The first one of your scripts I am going to use is pRINToPTO as I using used xy stages that hall effect limit switches on them that I have to check functionality on.
Is the arduino IDE enviroment suppose to display the output of the script on the display?
It doesn't with my Sanguino the only way I have been able to get it to work is disconnect the IDE from the comport and start a terminal emulator against the port.
Fred
> terminal.
> enjoy.
> -Leav
Re: Progress Update
November 19, 2008 05:04AM
While the Arduino is connected to the pc, there is a button next to "send to I/O board" which reads something like "open terminal"
When pressed it restarts the Arduino and prints out whatever the arduino jabbers about on the serial line.
should be the same for the sanguino as far as I know....
-Leav
Re: Progress Update
November 28, 2008 06:23AM
Hey!
Have you tried your lovely drawing reprap with the g-code arduino firmware?
I'm planing to build something like this my self and is curious about this.
Any thoughts about how to lift the pen from the paper and move to another location?
sid
Re: Progress Update
November 28, 2008 07:43AM
You can use a solenoid to gently push the pen to the paper (just like most plotters do)
should be fairly easy to accomplish and control.
'sid
Re: Progress Update
November 28, 2008 08:06AM
Wow! Thank you. That's a grate solution! smiling smiley
Martin
VDX
Re: Progress Update
November 28, 2008 09:04AM
... if you didn't want to feed power-wires to your toolhead, you can use a lever in form of a L-shaped alu-profile along your Y-arm which lifts the pen when been turned by a solenoid or small motor.
Some good oldstyle XY-plotters use this instead of a solenoid in the head ...
Viktor
Re: Progress Update
November 30, 2008 09:27AM
Could I use the reprap DC motor driver to drive the solenoid?
sid
Re: Progress Update
November 30, 2008 10:35AM
I'd say I'd prefere the pwm* driver but yes.
(*because you cannot "reverse" a solenoid)
Just take care of the settings for current winking smiley
'sid
Re: Progress Update
Yes if it takes less than 0.75A but a better way would be to use the PWM driver board which will drive more current and with less power losses.
The DC motor board is bidirectional so motors can be reversed, but that functionality is not required for a solenoid.
