Need some help with a prusa buy.
Posted by Jakecheramie
February 10, 2013 04:00AM
Hello, this is my first build and it is going to be a prusa mendel v2. I have bought these parts and would like to know how to buy the wades extruder. I am confused on what parts to buy because i was purchasing the parts off of the list on reprap but it got kind of confusing when i was going to buy an extruder and the part where it heats and pushes the filament through. Here is the parts i have bought.
NEMA17 Stepper motor 1.8 degrees step 5.5 kg cm Reprap Mendel Prusa 3d Printers
Quantity 5
2 Meters of T2.5 Timing Belt + 2 Pulleys Reprap Mendel Prusa Printrbot Orca
100 - M8 nut
100 - M8 washer
50 - M3 x 20 hex bolt
50 - M3 hex nut
50 - M3 flat washer
9 - M3 x 10 hex bolt
3 - M3 x 40 hex bolt
3 - M3 x 8 set screw (grub screw)
1 - M8 x 20 set screw (grub screw)
1 - M8 x 50 set screw (grub screw)
(Bought in a kit but not sure if it came with all parts necessary )
Lot of (12) LM8UU Bearings & (6) 608ZZ Bearings.
Full set of bearings for Prusa Mendel and Extruder.
The kit includes 8mm threaded rods (M8x1.25 threads) US sourced and milled.
3 x 440 mm
6 x 370 mm
4 x 294 mm
2 x 210 mm
8mm O-1 hardened drill rods (smooth rods) US sourced and milled. This is high quality tool steel, much better quality than the rods available at the local home improvement store,
2 x 420 mm
2 x 405 mm
2 x 350 mm
Reprap Prusa Mendel Plastic Kit V2(I2) Complete... LM8UU Version
Complete set of RAMPS 1.4 electronics (FULL SET)
If anyone could guide me in the right direction that would be great.
Edited 1 time(s). Last edit at 02/10/2013 04:02AM by Jakecheramie.
Re: Need some help with a prusa buy.
February 22, 2013 03:48PM
I'm not sure of your exact question: depending on your extruder they are typically broken into two main parts the hot end and the cold. The cold end consists of a nema 17 stepper, a larger gear, a smaller gear, washers, nuts, hobbled bolt and mounting bolts. The hot end is a little more difficult because there are so many different designs. If you have any other questions feel free to message me. If you want to get a basic idea of how they work I have posted info here.
--------------| For Everything |--------------------------
Check it out here:
[reprapsquad.wordpress.com].
---------| For Everything Prototype Related |------
Now featuring comp case mods:
[RepRapLab.wordpress.com]
--------------| Find us at Twitter|------------------------
@REPRAPSQUAD (RS Main)
[mobile.twitter.com]
@REPRAPSQUADHQ (ProtoLab)
February 25, 2013 09:35AM
I would buy an Arcol hotend, a LulzBot´s Budaschnozzle (based on Arcol) or a J-Head...they are far better than the original. The Wade´s cold-end (printed parts+NEMA motor+hobbed bolt) is quite standard...but I recommend replacing the plain gear+pulley with "stoffel15" herringbone gear+pulley on Thingiverse.
