After being burnt by cowboy e-bay retailers I am searching for a J-head hot-end that is properly built and does what it's meant to do.
I note that reifsnyderb has given good feedback on the J-heads built by Creative machines ( [
jheadnozzle.blogspot.ie] ) - which obviously is a good sign. Before spending any more money, though, I was just wondering if anyone has feedback on - e.g. - a few weeks of use.
In particular, I need a 1.75mm version that is compatible with a Rostock bowden cable setup.
Any feedback is appreciated.
D
P.S. I have ordered from hotends.com (the original designer) in the past - and naturally that hot-end worked as expected - but would prefer to order from someone on this side of the Atlantic in this instance - if possible (a little bit under pressure time-wise).
Semi-commercial engineering |
Reprap diary
