Heated Bed Died on me.
Posted by Crispy
February 20, 2013 03:32PM
Hi Guys,
I have beeing running a Mendel i2 with Ramps 1.4 and a 16A 12V PSU for some time now.
Some time ago the Bed stopped working, I came to the Frum and read about adding a FAN for the MOSFET, did that and the Heated bed came back to life.
Yesterday, after somo 12 hours of printing the Bed simply stopped working.
I have tryied (with no luck):
1) Removing all power and switched ev. back on
2) Verified all conections and solder points.
3) Unplug the MK2 Heated bed and Plug a Brand new MK1
4) Tested the Resistor and it Reads 0.972 Omhs
5) Tested the Heat Bed and it Reads 1.1 Omhs (the MK2 which was running) MK1 Reads 1.5 Omhs
6) With temp set on PrintRun the E8 ports is sending 4 Volts. Ev. else was turned off.
7) Power supply provides 12.2 Volts at both ports (which connect to both ramps inputs)
Looking for Ideas / Suggestions.
Regards
Crispy
Quilcam
Buenos Aires - Argentina
Re: Heated Bed Died on me.
February 21, 2013 03:43PM
Crispy,
it sounds like a bad MOSFET.
With the heated bed turned on can you measure the voltage at the gate? It should be 5V.
If there is 5V at the gate and there isn't 12V at D8 then you've probably got a bad MOSFET. Do you have a heatsink on it? If not replace the bad MOSFET and add a heatsink. Blowing a fan on the RAMPS board isn't a bad idea.
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
February 21, 2013 08:45PM
Thanks for the tips akhlut .
I'll get to that tomorrow.
Do you know if there is a way to test the MOSFETs with a digital multimeter???
Thanks
Crispy
February 22, 2013 01:41AM
Yes, Akhlut told you exactly what to check.
February 22, 2013 10:09AM
Ok, Done that, and it looks like the MOSFET is dead.
Difficult to get the multimeter in there tough. It does have a heatsink and, yes I have a quite big cooler (PSU size) there. Looks like 30 hours of straight printing was too much...
Will replace and come back.
Thanks for all the info.
February 22, 2013 11:45AM
They're easy enough to replace. Just snip the leads off at the body of the MOSFET and desolder the pins individually - much easier. You may need some solder-wick to clean out the holes before getting the new FET in there.
- akhlut
