Hello
I'm new to repraps and electronics in general and need some help.
So I'm following the directions to a T on my reprappro Mendel . So far so good till I got to the power supply. I got everything wired and got good connections to all plugs and contacts on the power supply but in the directions it says that I should get 0 olms when touching the ground plug on main ground wire and the case to power supply and I get a reading that gives a number till I hold it there for 15seconds till it slowly drops to 0. Is this ok? Also what setting should my multimeter be on? There's so many setting on it for olms. There is 200, 2k,20k,200k,2m,20m,200m all in olms section? It only goes to 0 when it's on 2m setting. All other ones flash different #s then they go away. I feel like a idiot!
I'm trying hard to learn this stuff but I'm feeling overwhelmed with this part I've checked all wires to make sure there not touching any others. Can any one help me?
