z axis spring solution
March 19, 2013 08:59AM
Hey everyone,
I am finishing up my mendelMax 1.5 and I am noticing that when I try to zero out my z axis, at the very bottom when I turn the motor, the rod is turning slightly, however, the extruder seems to not move for a few micro turns, then all the sudden kind of clunk down to the bottom and make up the lost turns.
I am not sure what this is, but I have seen some use a spring solution in the Z axis between two nuts.
Anyone have any suggestions?
If I should try the spring solution, can anyone explain or point me to a link on how to do it?
Thanks!
Re: z axis spring solution
March 19, 2013 01:39PM
What kind of Z-axis couplings do you have?
A pic would be good if you can.
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
March 20, 2013 12:04AM
Look around on youtube. I watched a video a couple weeks back where someone demonstrated installing a spring in an x-end for the z-rod. It was exactly what you're looking for.
ΜΟΛΩΝ ΛΑΒΕ
March 20, 2013 04:30AM
Do you mean one side of the X axis is hanging up when the axis is being lowered? If so, then your bearings on that side are binding on the smooth rod.
March 20, 2013 06:37AM
Everyone, thanks for the replies.
I discovered that my x carriage was not 100% level on both sides, so it was binding on one side.
Once I got it exactly level, this stopped happening.
Thanks for your help everyone!
March 20, 2013 02:02PM
The spring between the two nuts is a method used for anti-backlash. I've been using that method since my first RepRap. It works by putting opposite force tension on the nuts which in turn takes out any slack on the threaded rods. I recommend it. Its always served me well at least. It was a method that is borrowed from CnC builds. I used to build CnC's. I'm glad you got it figured out.
--------------| For Everything |--------------------------
Check it out here:
[reprapsquad.wordpress.com].
---------| For Everything Prototype Related |------
Now featuring comp case mods:
[RepRapLab.wordpress.com]
--------------| Find us at Twitter|------------------------
@REPRAPSQUAD (RS Main)
[mobile.twitter.com]
@REPRAPSQUADHQ (ProtoLab)
March 22, 2013 02:50PM
I found the video again for those that want to understand how it works: [www.youtube.com]
ΜΟΛΩΝ ΛΑΒΕ
March 22, 2013 06:37PM
Reprap squad and knimrod, thanks guys. This may be an upgrade I try to make once I get printing if I am not happy with the accuracy.
Very helpful, thanks!
March 23, 2013 12:37AM
Ya no prob we are always here to help. I've never really compared the difference between with and without the spring for anti backlash. I have with CNC'S but never on repraps so if you ever do a before and after I would love to see the results. Keep me updated.
Check it out here:
