New user with firmware issues.
Posted by Evo5422
April 01, 2013 07:08AM
Hi I'm currently building a Prusa with Sanguinololu board being controlled with a mac. Sprinter is the firmware.
The issue I currently have is that when I plug in my mechanical endstops my motors either stop turning or only go in one direction.
I'm aware that this is possible to fix in the firmware but as my board was already pre flashed i have no experience with it. I've tried to follow the instructions at [sanguino.cc] but the instructions don't seem to line up with the current IDE files.
I've also looked at these instructions.
[dustsreprap.blogspot.com.au]
The wash up of this is that in my version of the IDE there is no Sanguinololu board to select. And as such my board can't (?) be flashed.
This is my board:
[www.ebay.com.au]
These are my endstops:
[www.jaycar.com.au]
I can rewire my endstops so that they are normally open as opposed to the currently normally closed (continuity when switch open)
Thanks for any help you can provide. I'm very excited to be part of your community and one day hope to be of help.
Cheers
Rob.
Re: New user with firmware issues.
April 01, 2013 07:50AM
Rob,
have you seen this page?
https://github.com/kliment/Sprinter
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
April 01, 2013 08:45AM
Thanks for the suggestion Akhlut. Which part should I be concentrating on? I'm not working in Ubuntu im working in Mac OS 10.8.2.
Cheers.
April 01, 2013 01:36PM
Unfortunately, I'm not all that familiar with Macs. sad smiley
This thread may help.
Good luck!
- akhlut
April 01, 2013 08:16PM
I seem to be progressing. My board is now in the IDE drop down and I can start the firmware uploading, however I get the following error;
avrdude: stk500_getsync(): not in sync: resp=0x81
avrdude: stk500_recv(): programmer is not responding
Any ideas?
Edited 1 time(s). Last edit at 04/01/2013 08:23PM by Evo5422.
April 02, 2013 07:37AM
Hi guys, happy to announce that my firmware now flashes.
If anyone else with a Sanguino board has trouble, I have used Arduino IDE 1.0.1 with the most recent Sanguino firmware.
Make sure you select the correct chip for your board. I wasn't getting a firmware that used the 1284P chip.
Also make sure you don't have pronterface or some other software using your port.
Thanks to Akhlut for replying and giving it a shot.
Cheers.
