How to get extruded ABS to stick to print bed? April 02, 2013 09:01PM |
Has anyone tried this? Does it work, and how should it be done? Is the problem my surface? Or do I just need to get a heated print bed?Quote
On a cold bed ABS can be printed on masking tape by putting a thin layer of super-glue (cyanoacrylate) on the tape before printing.
Re: How to get extruded ABS to stick to print bed? April 03, 2013 01:43AM |
Re: How to get extruded ABS to stick to print bed? April 03, 2013 03:49AM |
Re: How to get extruded ABS to stick to print bed? April 03, 2013 04:45PM |
Re: How to get extruded ABS to stick to print bed? April 04, 2013 01:55AM |
Re: How to get extruded ABS to stick to print bed? April 11, 2013 08:29AM |
Re: How to get extruded ABS to stick to print bed? April 11, 2013 12:47PM |
Re: How to get extruded ABS to stick to print bed? April 12, 2013 04:28PM |
Re: How to get extruded ABS to stick to print bed? July 22, 2013 08:08PM |
Re: How to get extruded ABS to stick to print bed? July 22, 2013 09:35PM |
Re: How to get extruded ABS to stick to print bed? July 22, 2013 10:22PM |
It is important to be safe when experimenting with stuff...
I have to get back to this.
The glass transition of PP is wayyyyyyyyyy too low and it seems warp when it comes into contact with the hot extruded ABS. Then again, I was using a 2mm sheet that I cut out of a PP box using my laser cutter. I think a thicker sheet of PP would help. Today I also tried printing ABS on a heated plate of laser raster engraved glass (results in a surface almost identical to sand-blasted glass) at several temps up to 140C but it performed about as well as plain glass... Nothing I try seems to be working!|
Re: How to get extruded ABS to stick to print bed? July 22, 2013 10:37PM |
Re: How to get extruded ABS to stick to print bed? July 22, 2013 11:06PM |
I will try this again with a sheet of glass at room temp and see how it turns out.
Re: How to get extruded ABS to stick to print bed? July 23, 2013 12:14AM |
Re: How to get extruded ABS to stick to print bed? July 23, 2013 02:21AM |
Re: How to get extruded ABS to stick to print bed? July 23, 2013 02:44AM |
It would be an interesting experiment.|
Re: How to get extruded ABS to stick to print bed? July 23, 2013 11:48AM |
Re: How to get extruded ABS to stick to print bed? December 25, 2013 01:54AM |
Re: How to get extruded ABS to stick to print bed? December 25, 2013 04:44PM |
Re: How to get extruded ABS to stick to print bed? December 25, 2013 06:15PM |
Re: How to get extruded ABS to stick to print bed? December 25, 2013 10:42PM |
Re: How to get extruded ABS to stick to print bed? December 26, 2013 03:16AM |
uncle_bob
Well since we are dredging up fossil threads. ....
Hair spray on glass works just fine. It's far more "level" than anything you can do with tape. If you want a thin first layer it's the right way to go. It's about as cheap as anything else.
Re: How to get extruded ABS to stick to print bed? December 26, 2013 08:28AM |
Re: How to get extruded ABS to stick to print bed? December 26, 2013 12:33PM |
Re: How to get extruded ABS to stick to print bed? December 26, 2013 12:57PM |
Floyd
I just use a clean glass bed heated to 110c and right before the print I put a thin layer of the purple elmers glue stick down and it holds great!
Clean up is just warm water and wipe it off, no scrubbing or anything.
Normally I can get 5-8 prints before I build up enough glue to need cleaning.
Re: How to get extruded ABS to stick to print bed? December 26, 2013 01:30PM |
RP Iron Man
I briefly tried ABS glue but I had trouble applying an even coating to the glass. At first I would apply the ABS glue mixture and it would be too thick, so I would wipe the bed with acetone and end up removing all of the ABS from the glass
Re: How to get extruded ABS to stick to print bed? December 26, 2013 01:37PM |
RP Iron Man
Yeah, me too. Elmer's glue works so well! The parts also pop off the bed by themselves once it cools
Re: How to get extruded ABS to stick to print bed? December 26, 2013 05:32PM |
Re: How to get extruded ABS to stick to print bed? December 26, 2013 05:46PM |
Re: How to get extruded ABS to stick to print bed? December 26, 2013 06:39PM |
