Re: Design nearly done - construction started... May 25, 2013 09:06PM |
Re: Design nearly done - construction started... June 06, 2013 07:13PM |
Re: Design nearly done - construction started... June 06, 2013 07:55PM |
Actually I get excited to build my own..however I have no experience at all..
and thanks for update your progress and keep us motivated into start as well.
Re: Design nearly done - construction started... June 06, 2013 09:48PM |
Re: Design nearly done - construction started... June 07, 2013 11:03AM |
Re: Design nearly done - construction started... June 07, 2013 05:12PM |
Re: Design nearly done - construction started... June 08, 2013 07:25PM |
Frame welding complete.... June 17, 2013 04:56PM |
and more are drilled and tapped, all machining processes are done at this point because all had to be complete prior to assembly. All in all, 34 pieces of 1/8, 1/4, and 3/8" thick steel are brought together into a single rigid weldment, which is trued in 3 dimensions. Still, there is approx 14 mm total adjustment allowed by the rod adjustment hubs, which will be added soon in the build. Here is a pic of the frame, ready for a few last bits of grinding, in its raw glory.
Finally... The frame is complete June 19, 2013 09:36AM |
Re: Design nearly done - construction started... June 19, 2013 06:13PM |
Re: Finally... The frame is complete June 19, 2013 07:44PM |
Re: Finally... The frame is complete June 20, 2013 01:30PM |
Re: Finally... The frame is complete June 20, 2013 03:10PM |
Re: Finally... The frame is complete June 20, 2013 06:02PM |
Re: Finally... The frame is complete June 20, 2013 07:13PM |
Re: Finally... The frame is complete June 21, 2013 01:21PM |
Re: Finally... The frame is complete June 21, 2013 06:27PM |
Re: Finally... The frame is complete June 21, 2013 07:50PM |
Re: Finally... The frame is complete June 21, 2013 08:10PM |
Re: Finally... The frame is complete June 21, 2013 08:14PM |
Re: Design nearly done - construction started... June 22, 2013 01:22AM |
Re: Design nearly done - construction started... June 22, 2013 10:55AM |
Re: Design nearly done - construction started... June 25, 2013 05:08PM |
Re: Design nearly done - construction started... June 28, 2013 01:13PM |
Re: Design nearly done - construction started... June 29, 2013 09:24AM |
Re: Design nearly done - construction started... July 01, 2013 11:06AM |
Re: Design nearly done - construction started... July 06, 2013 10:11PM |
I did in fact have all the materials laying around except for the nuts and bolts. The end spreaders are PVC pipe pressed onto steel pipe; the spacers between the spreaders and the angle brackets were machined in steel, and powder coated, in practice for the powder coating I will be doing on some of the printer parts. This seriously falls under the category of "vehicle depicted with optional items"!
Now I can get back to work...
Re: Design nearly done - construction started... July 07, 2013 01:10PM |
Re: Design nearly done - construction started... July 12, 2013 10:52AM |
Re: Design nearly done - construction started... July 12, 2013 11:55AM |
