Re: Design nearly done - construction started... September 28, 2013 03:06PM |
Re: Design nearly done - construction started... September 29, 2013 06:12PM |
Re: Design nearly done - construction started... October 02, 2013 09:10PM |
Re: Design nearly done - construction started... November 04, 2013 04:34PM |
Re: Design nearly done - construction started... November 04, 2013 05:47PM |
Re: Design nearly done - construction started... November 07, 2013 02:40PM |
Re: Design nearly done - construction started... November 07, 2013 07:22PM |
Re: Design nearly done - construction started... November 10, 2013 06:47PM |
Re: Design nearly done - construction started... November 11, 2013 11:42PM |
Re: Design nearly done - construction started... November 12, 2013 11:26AM |
Re: Design nearly done - construction started... November 16, 2013 06:59PM |
Re: Design nearly done - construction started... November 17, 2013 12:17AM |
Re: Design nearly done - construction started... November 17, 2013 10:56AM |
Re: Design nearly done - construction started... November 25, 2013 07:27AM |
Re: Design nearly done - construction started... November 26, 2013 05:29PM |
holes in total. If all goes well in the morning, I will hopefully have this installed by the end of the day, though it will likely take an additional day to level and fine tune. Here's a pick assembled, there is also cross bracing not shown in this view.
Re: Design nearly done - construction started... November 26, 2013 07:27PM |
Re: Design nearly done - construction started... November 26, 2013 07:43PM |
Re: Design nearly done - construction started... November 27, 2013 07:03AM |
Re: Design nearly done - construction started... November 27, 2013 01:46PM |
Re: Design nearly done - construction started... November 27, 2013 07:45PM |
Re: Design nearly done - construction started... November 29, 2013 12:56AM |
Re: Design nearly done - construction started... November 29, 2013 03:27PM |
Foam is not a good candidate for use in an enclosed printer. It would melt or likely burn. Also, the electronics would fry. I would certainly say this was no easy part to make by hand, but ultimately is the optimal design for the overall goals of this printer. Besides, I had an Erector set when I was little, and always kind of liked that look. The general idea of making the frame in airship style came from an amp rack I built for my Miata, a 2006 I customized in '07, and still show. The idea was to add as little weight as possible, as the car is designed for perfect 50/50 weight distribution. Thru this design, the larger battery in front balanced the 2 amps and capacitor in the trunk, and the wire, the heaviest part runs fore and aft. Instead of building some traction adding fibreglass weighted 200 lb monster with amps that spin around etc, I opted to make a roughly 1/2 lb amp rack from aluminum, minimizing the weight of the installation, and not affecting the engineering of the car. In the case of the printer, where the weight of moving parts is important, as is air flow and temp control, this design seems to me to be the optimum choice. The carriage assembly, which is the next step, is going to be made in a similar style, though it will have fewer parts, and should end up extremely light in weight.|
Re: Design nearly done - construction started... November 29, 2013 03:37PM |
Maxx Mayhem
Well, all I would really need is a somewhat larger printer...
Re: Design nearly done - construction started... November 29, 2013 03:54PM |
Re: Design nearly done - construction started... November 29, 2013 06:29PM |
Re: Design nearly done - construction started... November 30, 2013 01:22PM |
Re: Design nearly done - construction started... December 14, 2013 07:20PM |
Re: Design nearly done - construction started... December 15, 2013 03:31PM |
Hopefully, I'll have more pix later in the week.
Re: Design nearly done - construction started... December 16, 2013 10:19AM |
Re: Design nearly done - construction started... December 16, 2013 11:31AM |
